gimbal not function
asaethon
Indonesia
Hi there.
I have some problem with my gimbal.
it won't move to any direction, even i use shortcut on C1 or C2.
I already try to calibrate the gimbal until finish but it doesn't even move when calibrating until finish the calibrating.
the gimbal status say it OK, not overloaded.
its looks fine on the status at dji 4 apps.
Please help me.
Thanks.
2019-2-11
asaethon
Indonesia
it looks lke it when I start the drone.
it won't move again even I try to calibrate or move upward or downward.
btw my dji account is setsumaru22@gmail.com
please help.
Thanks
2019-2-11
DJI Gamora
Hi there, thank you for reaching out and we're sorry to hear about the trouble. About that may I ask when turning on the Aircraft does the gimbal at least moving and Initiating? Also, do you still have a live feed from the camera? However, as you mention even you calibrate it. It won't move I would suggest reaching out one of the support channels In order to guide you on what you'll need to do. You may just go to this link https://www.dji.com/support Thank you for your support.
2019-2-12
ALABAMA
Flight distance : 10442687 ft
Did you just do a firmware update?
2019-2-12
asaethon
Indonesia
ALABAMA Posted at 2-12 12:58
I already check the firmware at dji assistant and the firmware is still same from the beginning.
I never run the update for the drone or RC.
2019-2-12
asaethon
Indonesia
DJI Gamora Posted at 2-12 10:33
the gimbal just move like in the video, and I still have the live feed from the camera.
it can take photo and video, but it won't move to any direction
2019-2-12
DJI Gamora
asaethon Posted at 2-12 16:56
I'm sorry to hear that, If that the case, Unfortunately. What I can only recommend is send it into the facility for further checking of the issue. You may just go to the link https://www.dji.com/support for you to have the guide on what you'll need to do. Thank you for your support.
2019-2-13
