Shrikkanth
India
michaeltolar Posted at 6-28 16:18
SOLUTION! LOOSEN screws, not tighten!
Hi guys, I've been searching these forums for the last few hours, as I had the same ticking issue. I determined that the ticking noise was only happening on the TILT axis (the one on the top-right). I started tightening screws that I thought could be problematic. The noise only became worse. I couldn't put my finger on it, but the sound, combined with the subtle "impact" I was feeling when the click occurred, led me to believe that there was some kind of internal interference happening with a fastener. Maybe the inner end of one of the set screws was too far in, and was hitting pieces of a component on the adjacent rotating mechanism. Anyway, I started LOOSENING those three outer screws (next to the word "RONIN" by the tilt axis motor, and the sound disappeared. This may not be the real solution, but it seems to have worked for me. Hope this helps.
Hello,
Thank you so much for this. Loosening the screws actually helped !
