DJI Tony
Hi, thanks for the inquiry. For Osmo Pocket, the video splitting mechanism is the same as other aircraft. The maximum capacity of a single file will not exceed 4GB. If exceeded, the recording will be stopped, and a new recording will be started. Please see the explanation below for your reference. Kindly keep us posted if you have other concerns. Thank you for continued support.
1. For SD cards with a memory less than 64GB, the only FAT32 file system can be used (SD Association stipulates that files can be formatted into exFAT in Windows system for non-standard usage). Files larger than 4GB cannot be stored on a FAT32 volume.
2. For SD cards with a memory greater than or equal to 64GB, the only exFAT file system can be used (which is specified by SD Association). Theoretically, a single file can exceed 4GB. However, in order to avoid errors resulted from files being too large, we still split files when the capacity exceeds 4GB. |
