Cetacean
Flight distance : 2528264 ft
Aloha Edward,
It turns out that Active Track is not able to fix and track on an object as small as another Phantom. I tried tracking a P3 Advanced (with propguards no less) using my P4 Pro and while the P4 Pro could get a fix, it could not track the P3A. The P4 Pro would rotate to the P3A but would not move and eventually lost the tracked image.
One of the Administrators said he had also tried it and was not successful. When I was trying these tracking experiments, I tried to be above the tracked Phantom so I could get a larger object to track.
I think the problem with that crash was the two Phantoms have similar sensors in the front and they were facing each other within range of each other. The signals confused and / or jammed the sensors and you recorded the results.
Why were they facing each other? Tracking usually involves following an object that is not traveling toward the tracker. As some of the other commenters said, the sensors may have been too close to each other and I would agree. But then Active Track requires sensors to. Interesting question.
Like you, I have been curious about a quad tracking another quad, as noted. I still have not tried to track my P4 Pro with my Mavic Air yet. With this thread's information, I will be a little more careful just in case. Mahalo for the information!
Aloha and Drone On! |
