How to stop wobbling props and gimbal shake.
2868 20 2019-2-13
Webevision
Flight distance : 5906043 ft
Hi,
I actually posted this on my other tread but I thought it worthwhile a seperate post of its own.
For those picking up either micro wobbles or vibration coming through on their camera, this work around might solve it. There are several clips on Youtube which give you an alternative methods of fixing prop wobble, inparticular with the red ones,such , gluing, adding shims, strapping stuff on, but this one seems a bit simpler.
As you can see from my previous posts I've been having really bad issues of wobble or shake coming through onto the camera. My conclusion...I think ! Is similar to bad alignment on a car wheel, if the loose props hit a certain frequency together or independently, they transfer tremors to the gimbal which can't deal with it and makes the shot unusable. Although I’ve only tried this a few times, it seems to sort it out, and it seems a pretty low cost way of dealing with it!
For those who try it, any feedback would be very much appreciated.
Cheers
Phil
2019-2-13
Webevision
UPDATE- THIS DOES NOT WORK!!
Just when I thought I had cracked it, it actually made it worse! So please don't try this at home kids!
Sorry for all the false hope.
2019-2-15
ElectricLife Atellani
Flight distance : 9674836 ft
Webevision Posted at 2-15 07:34
These work quite well and they can be added and removed in minutes:
2019-2-15
BagoDJIoperator84
Flight distance : 1077608 ft
ElectricLife Atellani Posted at 2-15 14:04
[view_image]
[view_image]
Who make these?
2019-2-15
Matthew Dobrski
Flight distance : 1831050 ft
https://www.atellani.com/introducing-ultimadrone-dji-inspire-2-propellers-fix.html
They're selling these in a set of 6 shims: 4 x .005" thick and 2 x .006", all stainless steel. Really ultimate and permanent solution.
2019-2-15
BagoDJIoperator84
Matthew Dobrski Posted at 2-15 18:27
wow, pretty expensive but hope they solve the issues. I dont own an Inspire as yet  maybe soon though.
2019-2-16
Matthew Dobrski
BagoDJIoperator84 Posted at 2-16 05:36
Keep in mind that the rattling issue is not persistent nor consistent with Inspire prop mounts. Your's may be perfectly OK. Metal shims, however, seem to be the one and only permanent cure for these with loose props. DJI's rubber foam cushion inserts do camouflage the issue for a while, but doesn't solve it.
2019-2-16
BagoDJIoperator84
Matthew Dobrski Posted at 2-16 14:14
Thanks for the reply I really appreciate it.
2019-2-17
Matthew Dobrski
BagoDJIoperator84 Posted at 2-17 05:12
Glad to help.
2019-2-17
dldp-sp
Flight distance : 1065902 ft
I have commented on this issue before and again, I am not convinced that the rattling props are really an issue. Sure they make some noise when you spin them by hand but, Once those motors start up they lock in place and don't move because of the extream centrifugal force. I have made shims for my inspire and see no difference in flight with or without them. I do keep the shims in place just for a "warm fussy" feeling but other than that, Not sure they really do anything. Can anyone show me some real evidence that this has some real positive effect?
Regards,
Tom
2019-2-18
Matthew Dobrski
dldp-sp Posted at 2-18 04:04
Regards,
You're absolutely correct. The looseness/rattle is merely an annoyance and has nothing to do with propellers performance, vibrations or flight safety. With one correction: this is up-ward thrusting force (not centrifugal, as you think), which eliminates the rattle during flight.
Bottom line: all rattle eradicating solutions (sophisticated metal shims including) are developed by those of us who can not tolerate any imperfections ... Nothing more, nothing less.
2019-2-18
fansb1d527d7
Flight distance : 1573547 ft
Austria
[view_image]
[view_image]
I have these as well, and they work great. However, I wish there would be a 0.003 Version as well.
Cheers
2019-2-18
fansb1d527d7 Posted at 2-18 12:42
Cheers
We might make a .004 series in the next batch (Not the one shipping these days).
2019-2-19
wisnia1010
Flight distance : 2234938 ft
Poland
ElectricLife Atellani Posted at 2-19 01:25
Any discount for someone who bought an Atellani Ultimadrone Safety Kit in the past ?
2019-3-2
wisnia1010 Posted at 3-2 01:26
Dear Wisnia1010, please write to: isabela@atellani.com
2019-3-2
DaBone
Sweden
And I just cut a little electric tape and stuff in the propeller. Works fine..
2019-3-2
DRAGenDROP
Flight distance : 26170253 ft
Great, but!!!!
DJI have to come with a free solution , they will not come with it, wy, it's like this from the start and like you to buy a Inspire 3, so they will NOT come with a solution.
They tell you that it's not a problem and that's it
Thanks DJI, Great Job, NOT
2019-3-2
Matthew Dobrski
DaBone Posted at 3-2 05:03
For a while.
2019-3-2
DaBone
Sweden
Like everything else that cost a lot of money?
2019-3-15
epicjib
Flight distance : 3016060 ft
Matthew Dobrski Posted at 2-18 12:22
You're absolutely correct. The looseness/rattle is merely an annoyance and has nothing to do with propellers performance, vibrations or flight safety. With one correction: this is up-ward trusting force (not centrifugal, as you think), which eliminates the rattle during flight.
I have these shims (Thanks Matthew) and I have to say my i2  is dialed in better than ever. It is quieter and flight characteristics are very stable and predictable like it should be. I would say if your props wobble use these shims.
2019-3-16
Matthew Dobrski
epicjib Posted at 3-16 06:52
Thank you, bro. I'm glad you're happy with these shims ...
2019-3-16
