Monk32
Flight distance : 50915 ft
Greece
DJI Tony Posted at 2-18 16:21
Hi, we're sorry that you had a problem calibrating the sensor of your Mavic Air. However, we're glad that you've rectified the concern via uninstall and re-install the application. Please let us know if you have other concerns. Thank you for continued support.
That's the benefit of a huge "family" community. We all are continuously support each one and all together.
Answering your requisition about other concerns I have an experience which may help a lot of users.
I had a connection error, with the MA refusing to connect with controller. After a brief search I found out that the cause was my SD card which was faulty. Just replacing it and the connection was a matter of seconds. So please inform users that a faulty memory card may not let connection established and that is not a system malfunction., and before deciding to send the drone to service, they got check the SD card for fault.
