Joller79 DK
Flight distance : 26447 ft
Denmark
Aerial-Image Posted at 2-18 07:47
Cheers will see what we do next...I know there is a full camera/gimbal unit available for around $130 but might be better just to send it in...LINK - but everything was ok with the drone before we removed the camera so should be ok with a new gimbal, or is it better to send it in - as its not in warranty.
Usually replacement parts from ebay, are from teardowns of drones, so genuine..
First question. Did you have picture before teardown?
2. You reused all wires etc , only gimbal housing was swapped?
If yes to both, then you either bent wire connector, or broke wires(usually the point where you route them in gimbal, or before you twist them to motherboard connector.
I would try and measure connectivity in wires, or just buy a new wire to gimbal/camere/
Edit.
https://www.ebay.co.uk/itm/GIMBA ... 2tsx1tQtE5PdrIXKoIA
Or
https://www.ebay.co.uk/itm/Origi ... :g:RukAAOSwQcJZ9wPc
