Udo13
Flight distance : 257188 ft
- Timelapse interval 0.5s and 1s
-- Backup of files on iPhone does not take place in 4k, then better remove the possibility
- Is it not possible to keep the Exposure setting selected in Pro mode even after switching off and on again?
- In many cases, the picture is too bright for me. There would be a persisting setting of -0.3 EV or even -0.7EV very favorable.
- Some personal settings in the "Video" section are unfortunately lost each time you turn off the power. For example, the gimbal setting, but also the brightness. But if you set it to "manual", then the Pocket suddenly remembers that.
- The volume is reset to "medium" unless it is set to "automatic" ... and the white balance to "manual".
- Incidentally, Pocket does not notice the exposure compensation in photo mode.
This is all a bit inconsistent and not conducive to reliable filming. If I'm of the opinion that the camera exposes too brightly, then that is a property that is almost always true. You do not have to change that every time. |
