Waypoints 2.0 - Stuttering Yaw
2478 8 2019-2-18
NGaDronePilot
Flight distance : 607815 ft
LITCHI has had a bug with Mavic 2 that causes stuttering in the yaw movement when transitioning between waypoints or focusing on a POI. Instead of a smooth movement, it stutters, making the resulting video essentially unusable. Now that Waypoints 2.0 has been released, we're seeing the exact same issue in DJI Go 4. This leads me to conclude, as LITCHI has said all along, that it's due to a firmware issue with Mavic 2.
Does anyone know if DJI is aware of this? I'm certainly hopeful that they are working on a fix.
2019-2-18
DJI Natalia
Hi, we're very sorry to hear about the issue. Regarding that, I will forward your concern to our R&D department for further clarification. Would it be possible if you can provide a sample video of the issue? Please keep us posted for further help. Thank you.
2019-2-18
TrippleDelta
Flight distance : 2228182 ft
Belgium
I’ve seen this on all my waypoint missions. Very disapointing.
2019-2-18
fans19322c80
Flight distance : 1293468 ft
I have the very same problem. When flying in a arch around a POI the drone adjusts very stuttery and inconsistent. Would be great if it worked as smooth as the visual based POI flying mode.
2019-3-11
NGaDronePilot
DJI Natalia Posted at 2-18 08:44
Please watch this video starting at minute 13:00
2019-3-12
NGaDronePilot
I've posted a YouTube link that illustrates this issue perfectly.
We're seeing this STUTTERING movement when Panning on a Mission.
The Video is NOT smooth - and appears to intermittently "CATCHUP" with a quick movement - as if the gimbal has been freed from being stuck.
The video then is Unusable. This issue is being widely reported by hundreds of Mavic 2 owners, but I've yet to see an official DJI response. Are they working on a firmware fix?
2019-3-16
BobbyC
Flight distance : 1401522 ft
I  have seen this exact same thing!  Does DJI plan to fix this???
2019-5-1
SlickR
Flight distance : 642559 ft
Any news on this, it's been a while and Waypoints 2 is still completely USELESS?
2019-6-19
NGaDronePilot
SlickR Posted at 6-19 12:57
Thank heavens, YES!! The latest firmware update finally fixed this issue. I can't tell you how happy I am that this is finally working properly.
2019-10-5
