Coyut
Flight distance : 2559222 ft
Switzerland
Matthew Dobrski Posted at 2-19 13:53
Make sure you update Cendence firmware with patch antenna ATTACHED! Antenna itself is very directional, not like standard omni-directional sticks. But should provide strong signal for broadcasting when correctly aimed at the drone. I had 6 km transmission with Matrice 200, maintaining clear LOS (Line Of Sight).
FCC an CE mode also differs the max signal.
In my case I only got problems since the I2 .300 update.
Also the Go4 app crashes now very often. Temps are currently around C0°, so heat can't be the problem.
Also had it once that all chanells were shown fully red. 5Min later everything worked again. |
