RohdeScholar
DJI Stephen Posted at 2-19 09:54
Hello and good day. Thank you for reaching out. You need to calibrate the compass of your drone on the following scenarios. First, when the DJI Go 4 application prompts that the compass needs to be calibrated, the drone’s compass has suffered from interference as the aircraft was turned on in a place where there is magnetic interference. Make sure to fly the aircraft in an open area free of interference. Second, is when powering on the drone, ensure that the aircraft is at a standstill. If there is interference or the aircraft is powered on during movement, the compass’s orientation may be altered, and then re-calibration is needed. And third ensure the flight stability, the application will prompt you to calibrate the compass when there is a need. Please follow the application and calibrate it. Thank you for your support.
Hi Stephen,
As a newbie, I'd like to ask what may seem an obvious question:
How does DJI GO 4 tell you that the compass needs calibrating?
When I turn on the drone, control box, and DJI GO on my iPad, the status listing for Compass has an adjacent clickable box that says "calibrate." Does that mean the compass needs attention? Or is there a more conspicuous indication (like a red warning message on the top row of the display near the GPS bar graph)?
Thanks. |
