the sign H
554 1 2019-2-19
francobini
Flight distance : 70886 ft
What is the sign H  that appears when the drone is localized in the map?
2019-2-19
DJI Tony
Hi, thanks for the inquiry. I would like to clarify if you're referring to the map which is located at the lower right side of the application? If yes, then this would be the Homepoint of your aircraft where it was taken off. Please let us know if you have other concerns. Thank you for continued support.
2019-2-20
