DJI Support
Flight distance : 2408 ft
China
Overview
- Date: 2019.02.20
- Aircraft Firmware: v01.07.0118
- Remote Controller Firmware: v01.07.0116
- DJI GS RTK App: v1.8.25
- DJI Assistant 2 For Phantom: v2.0.6
- DJI Assistant 2 For MG: v2.0.12
What’s New?
- Improved battery stability and safety after the battery was not fully charged and discharged during long-term storage.
- If you have multiple batteries, please run this firmware update on all of them.
- Added support for the remote controller without a built-in display for use with Mobile SDK apps.
- Added Timed Shooting mode in Photogrammetry and Linear Flight operations.
- Added the option in Advanced Settings when planning a Photogrammetry operation to set the margin of the operation area automatically.
- Added support for export and import of the planned operations using a microSD card.
- Added support for RTCM 3.2 MSM3 when using custom network RTK.
- Added the option in General Settings in Camera View to select Grid as FPV Display Mode.
- Added the function to center the gimbal by double tapping the gimbal pitch status bar in Camera View.
- Cancelled the limit for the length of the flight route when planning an operation.
- Optimized the calculation for the flight route and operation duration.
- Fixed occasional issue: app crash caused by some random operations.
- Fixed occasional issue: there was no marker for the breakpoint after pausing the operation.
- Fixed occasional issue: the storage path of the pictures shot during automatic operations was wrong.
- Fixed issue: wrong display of some text in the app.
- Fixed issue: wrong display of GSD value when system language was Japanese.
Notes!
- This firmware update may take a long time. Please wait and DO NOT power off the aircraft during updating.
- Make sure that the firmware for both the aircraft and remote controller is up-to-date. Otherwise they will not work together.
- It is not recommended to use this firmware with a PC GS Pro of v1.2.0 or lower. Otherwise some functions may not work properly.
