Drohnenservice Usedom
Hi, in the moment its a little complicated but you can use autopilot with a combination between the GSP ans the Pilot App, first start the GSP App, choose the waypoint mode and set your waypoints, its important to switch the gimbal control to manual, otherwise you couldn't control the gimbal in the pilot app. Start the mission, than switch to the pilot app, it needs a few seconds to start, now you see "waypoints" on the remote display, you can switch between the camera views on the Dual camera, if you want to pause the mission, press the pause button, you can rotate, pause and control the gimbal, but you can't control hight and the speed, i use this for searching for fawns. its complicated but it works. |
