How to Fly Safely Over Water
12Next >
22523 65 2019-2-20
DJI Panda
Flight distance : 405039 ft
- By DJI Support
The prospect of flying over water can be a scary one for most drone pilots. Water environments are often filled with potential hazards such as boats, waves, high winds, and even birds. Although DJI does not encourage flying over water, professional aerial photographers and videographers will sometimes have to do precisely that. Therefore, this article offers constructive advice on what you can do before and during your over-water flight to ensure safety.
*Beginner pilots should refrain from flying over water at any time.
Disable Vision Positioning System (VPS)
All DJI drones come equipped with VPS, a technology that maps the surface below to help position the drone. When flying over water, however, light reflecting off of the surface can cause issues with this technology. Because of this, it’s best to maintain a height of at least two meters above the water. If you have to fly below this height, we recommend you turn off the VPS to avoid any unstable actions by the drone. The GIF below shows you how:
Plan Your Shot
Flying over water is always risky, but careful planning can help you avoid danger. Planning a shoot should include finding the right location, visualizing your ideal image/video, and doing a few test shots on land to make sure the angle is right. Going through these steps can help to ensure a smoothly-executed shot.
Enable Maximum Flight Distance
Although it can be tempting to fly long distances over water, we recommend that you always operate your drone within line of sight. If you’re planning a shot that requires flying long distances, make sure you set the maximum flight distance in the DJI GO 4 app. You can activate this function by entering the main controller settings and selecting “Enable Max Distance.” Input your new max distance, but make sure you keep it within range of your remote controller’s capabilities.
Practice
For obvious reasons, we recommend that you practice your takeoff, flying, and landing skills on land first before heading out over water. Mastering these skills will result in better control, increased confidence, and an overall safer flight in any location.
When flying over water, there are often two options: starting from land or starting from a boat. Takeoff from land is no different from a regular land flight. When starting from a boat, however, we recommend you takeoff while the boat is idle as it will be more stable and safe. Takeoff from a moving boat is possible at slow speeds but is not recommended.
Update Your Home Point Manually
When flying over land, the home point is usually where the aircraft took off from. Under ideal conditions, the aircraft will use its compass and GPS to automatically record a home point, which can be viewed in the DJI GO 4 app (see below). To learn more about using the Return to Home feature, please click here.
Using the original home point from a boat can be rather tricky as boats will often drift or move during flight. Because of this, it may be necessary to re-set your home point. There are two ways to do this using the DJI GO 4 app: first, swipe left on the main screen, and press “Home Point: Me,” second, open the general settings by pressing the three dots on the upper right corner, go to “Main Controller Settings,” and press “Home Point: Me” (the button with a person and home point below).
Avoid Obstacles
Many obstacles can endanger your journey over water, let’s take a look at some of the ones you need to watch out for the most:
Objects that Interfere with Compass or GPS Signal
Strong compass and GPS signals are essential when operating a drone. Make sure you avoid any objects or structures that have the potential to interfere with your signal. These include large objects like lighthouses and container ships, or any device that uses antennas, magnets, or Wi-Fi.
Natural Objects
When flying in areas near water, be sure to avoid trees, rocks, or any other natural structures nearby. Also (believe it or not) pay close attention to birds, as seagulls in particular are known to exhibit aggressive behavior towards drones.
Waves
Waves can be dangerous when flying too close to the water’s surface, requiring pilots to react fast or risk losing their drone. Make sure you stay far enough above the surface to avoid this issue entirely.
Boats
Boats of all sizes can be potentially hazardous for drones. Don’t fly too close to any boat, and as an added precaution, set your return-to-home height higher any time you are flying near a boat (especially a cruise ship or container ship).
Make sure you stay alert to these and other obstacles during your flight over water. If you notice any potential hazards it is always recommended you keep your drone on land and wait for a safer time to fly.
Use Your Intelligent Flight Mode – Course Lock
Intelligent flight modes allow you to create professional-level aerial footage with just a tap. One of the most useful modes for over-water flight is Course Lock, which lets users pre-set a flight path. The drone can then fly automatically, giving users more freedom to focus on getting incredible shots.
Be Aware of Wind Speed – It Will Affect Battery Level
As drone pilots know well, strong winds can result in aircraft instability during flight. Strong winds can also cause your battery levels to drop quickly. Unfortunately, wind is hard to avoid, and the higher up you go, the stronger it often gets. If you notice strong winds on the ground, it’s safe to assume there are even stronger winds in the air and you may want to consider delaying your flight.
This tutorial will teach you how to measure the wind speed using the DJI GO 4 app:
In conclusion, flying over water is dangerous, and even an instant of carelessness can result in a damaged or lost drone. As a pilot, always pay attention to your surroundings and focus on safely controlling your drone. Follow these tips and your chances of having a fun, safe, and dry flight will be greatly increased.
The content origins from DJI BUYINGGUIDES
2019-2-20
AirButterflyDrone
Flight distance : 4522884 ft
great tips
thanks DJI Panda for your sharing
I posted a my thread about fly over water more than 1 year ago ... but obviously , this your is much more better
but with your permit I would like to give my TIPS about it
for me , another important TIP, that I learned in " take off from a boat" event  is the
correct programming of the return to home.
What happens when you lose the radio signal?
I consider very important , like you said in your tips ,  the movement factor, this coming from a small drift , around a moring buoy or just from a normal transit ... but for sure , is very provably , to change position of the boat during the fly time
1st) so , I usually Check the RTH on my device in the DJI GO App and I change my RTH like that.
in this way , I think I have more chance to resume my beloved drone,
becouse he will wait for me until I will move the boat under him.
Provably the radio link will resume and everything will get to normal.
but above all, my drone, in case of problems will not return to home alone and maybe to will end up in the sea..
2nd) TIP - 20M Radius
let's not forget, the 20 meters radius, at least that we do not take off from an aircraft carrier ...
I usually take off from a very small boat,
so I have to keep in mind,
that the drone  consider 20m radius , like home point ,
and so is better do not activate any landing funtions in this 20m Radius, even RTH to avoid to land and fall in the water
3rd) when take off from a boat, like you said the skill  are even more important,
so in my opinion, it is better to land with 30% minimum battery charged...
this gave me more confident during the flight and more awareness of being able to return my drone in the boat, even with a slight movement....
set the low battery warning at 40% to be notified and the critically low battery warning to the minimum possible.
in this way I had enough time between the warning and the critically if something went wrong
luckily it never happened a lost signal ...
even when many boat radios were working , radar and others things the signal of the drone was always strong.
but prevention is better
4th) the last Tip to get better footage and picturs
looks top down , one time a friend of my said .
This is more important with video than stills, but can also simplify your still editing process.
When you point your camera straight down at the water, it often struggles to find the proper white balance and can bounce back and forth between colors.
By default, I usually leave my white balance setting on daylight and adjust if necessary
When pointing straight down on the water, highlights will almost always blow out when auto exposure is turned on.
I usually underexpose my footage between 2/3rds and a full stop to compensate and maintain nice highlights.
Another trick is to point your camera at the horizon, with the ocean taking up the lower 2/3rds of the screen,
then press the exposure lock button before moving your camera to the straight down position
the last but at same important level
a corret use of a ND Polarised Filters
this enable you to get the right shutter speed for non-flickering shots. (On very sunny days you can need up to ND32 )
and  they reduce the glare/reflection off of  water  ...
I hope this will be usefoul
Alex
www.airbutterflydrone.com/english
https://www.youtube.com/c/AirButterflyDrone
https://www.skypixel.com/users/carboni-vs
2019-2-21
P3KoYoT
Flight distance : 1846667 ft
Poland
Few more things:
- if you are attempt to fly close to the waterfalls you need to be carefull due to lots of humidity and heavy load of water.
- if you want to start your dron from the bridge, you can get problem with correct compass calibration due to interferences,
- when you fly low and away from the sight, remember that reflection in water can be tricky and you have be very carefully, distance between A/C and its reflection is bigger then distance of A/C from water,
2019-2-21
Flyingcougar
Flight distance : 654528 ft
Good tutorial Panda, thanks!
Would I be correct in assuming that one would want to disable the VPS if flying over snow as well?
2019-2-21
BigAbe
Flyingcougar Posted at 2-21 07:28
Personally i haven't had any problems flying in the snow with my mavic air. Which is probably because the snow doesn't reflect that much, it is more considered bright because of it's colours. The problem with flying over water is that it causes a different reflection because of acting as a weird mirror, this way the sensors may get confused. Which will probably result in losing the drone, or having a near death experience.
2019-2-21
GoldenSun
Poland
Great article, everyone should read this!
2019-2-21
RGMGFitness
Flight distance : 233757 ft
Great tutorial and information...I think this will benefit a lot of folks (hopefully they see it).  I think many are confused about how the Atitude Inicator actually works and can help with in flight conditions....great stuff!
2019-2-21
Flyingcougar
AirButterflyDrone Posted at 2-21 10:55
great tips
Also great tips Alex, thanks!
2019-2-21
Flyingcougar
BigAbe Posted at 2-21 09:33
Thank you BigAbe for the clarification!
2019-2-21
Wearion
Yesterday I lost my DJI in water (( very upset
2019-2-21
Reggy777
Water is #1 danger for copters
2019-2-21
AirButterflyDrone
Flyingcougar Posted at 2-21 11:56
It's my pleasure
I'm happy you liked it
2019-2-21
BigAbe
great tips
yes amazing tips!
2019-2-21
snowbird pilot
thank you!!
2019-2-21
DJI Panda
P3KoYoT Posted at 2-21 03:27
Few more things:
Thanks for your addition.
2019-2-21
DJI Panda
great tips
Great tips too! Thanks for it!!
2019-2-21
DJI Panda
RGMGFitness Posted at 2-21 10:50
Thanks
2019-2-21
DJI Thor
Flight distance : 13602 ft
Wearion Posted at 2-21 12:07
Wearion, we feel sorry to hear your loss, that must be frustrating. May we know which drone are you flying and when did you purchase it? We suggest that you contact the support at http://www.dji.com/support to start a ticket, if there is a doubt about the accident, data analysis will be applied as long as the drone is within the warranty period. We'll provide you with a corresponding solution according to the analysis result.
2019-2-21
goforheart
Latvia
thank you so much
2019-2-21
AirButterflyDrone
DJI Panda Posted at 2-21 18:29
hey DJI Panda
I am very happy and honored that you liked these
I hope these will be really useful to everyone that like to fly over water
maybe ... maybe ..would also be useful to talking about the DJI CARE Refresh program,
this will replace the DRONE if an accident happens, even if it is damaged by water ... what do you think?
for all users this is the link to take a look:https://store.dji.com/shop/service
Alex
www.skypixel.com/AirButterflyDrone.com
2019-2-22
Lysak2003
Flight distance : 500052 ft
Ukraine
Is it allowed on all types of DJI drones to turn off VPS?
2019-2-22
Lysak2003
Ukraine
great tips
[Image]
Hello! If you set shutter speed and ISO manually, it means exposure is already locked, isn't it?
2019-2-22
P3KoYoT
Poland
Lysak2003 Posted at 2-22 02:14
VPS it is Visual Positioning System - andthats not true that all DJI Drones have it.
2019-2-22
Hartyaj
Flight distance : 49478 ft
Thank you for such an informative tutorial, much appreciated.
2019-2-22
Lysak2003
Ukraine
P3KoYoT Posted at 2-22 03:09
We have VPS on DJI Spark, but I don't think it's possible to turn it off.
2019-2-22
AirButterflyDrone
Lysak2003 Posted at 2-22 02:20
hey, Lysak2003
DJI Spark very provably has settings with fewer options than a Mavic 2 Pro (Hasselblad Camera) or even better an Inspire 2 ...
I consider the Spark a very good (Consumer) drone from all points of view ...
I'm using one from  a long time , with the Portable Charging Station too
in many situations he was very useful ... to have it , has made the difference.
however, it remains a drone with the 2-axis gimbal and 1080hd camera.
(the panoramic photographs are WONDERFUL the videos excellent, it is very reliable and robust and small enough)
ps. yes, many cameras have this limit, on three one is locked and two can be set manually
2019-2-22
akozc
Flight distance : 2019951 ft
Macao
Thanks DJIpanda you are true guru  of droning I specially thanks for the advise on how to check wind speed video a kind of life saver to me. ++A from me.
2019-2-22
PWidmayer
Flight distance : 558268 ft
Great tutorial. I have several flights I would like to take over lakes and rivers. I will take all of that great information into consideration.
2019-2-22
Sayhelloforme
Flight distance : 8133219 ft
Good information here thanks.
2019-2-22
Tobe2d
Flight distance : 1584409 ft
United Arab Emirates
Great tips!
2019-2-23
DJI Panda
AirButterflyDrone Posted at 2-22 00:11
hey DJI Panda
Nice idea, thanks Alex!
2019-2-24
Keego63
Flight distance : 10082 ft
Thx for sharing these great tips
2019-2-24
apkwebs
Bangladesh
Great & it is very clear instruction, thanks for sharing
2019-2-25
aidenjames
India
Thanks for sharing;. . . . . . . . .
2019-2-25
jacksonnai
Malaysia
Very nice information!
2019-2-27
Luca Rubino
Flight distance : 711512 ft
"Use Your Intelligent Flight Mode – Course Lock"
But you removed it from the new Mavic 2 series! Isn't it?
It was a great features when I had the Phantom 4 ADV
I miss it!
2019-2-27
DJI Panda
apkwebs Posted at 2-25 01:54
Glad you like it.
2019-2-28
DJI Panda
Keego63 Posted at 2-24 23:48
2019-2-28
ReyCoen7
Kenya
This is a great tutorial for beginner pilots like me. I just acquired a [url]DJI Mavic Pro and am loving it. I had to practice on dry land first but now I think am ready for the seas. Yala!
2019-3-2
PWidmayer
Flying over water is scary but the video and photos you get are out of this world good!
2019-3-10
12Next >
