micholix_1
Austria
Bing Err Posted at 2-24 16:10
Wouldn't you want the weight of the gimbal to hang DOWN from where it's attached to your backpack strap. Seems like this mount would be top-heavy and bounce around a lot.
In my case, you can mount the OP on what ever position you like, excapt over the buttons for sure, even over the screen!
I mounted it just for the pictures at the almost vers bottom end for showing.
The backpack strap has a rotary part, so you can turn it 360 *, so it is good for a single strap pocket to, as you can adjust it at a correct angle, you would like.
Also you can mount it screen forward, or rearward, or in torch mode position on top of you shoulder, if you like... |
