I've been shooting 4K video 24fps with the MA and after processing the video via Wondershare or Adobe Premiere Pro and uploading to youtube it appears to be choppy.
If uploaded the raw video to youtube and changed to 1080p, its greatly smooth; but if I combine 2 videos and converting it with a software, it appears to be really choppy.
Combined and choppy:
Raw video file:
I was advised to shoot on the best quality possible (4K) and then to convert to any format; still, this is not working for me.
All I want is shoot in HD quality, combine videos and upload to youtube, yet for now this appears to be quite difficult as any combination results in choppyness.
DJI Gamora Posted at 2-21 08:33
Hi there, we really appreciate you for sharing your awesome and wonderful video here, well done and fly safely. Cheers!
Hi Gamora - there is an issue with the videos, would you please check?
I apologize, I Already checked again the video. May I ask before you upload it from Youtube the problem is already there or before you post process it? Please keep us posted. Thanks!
Are you making sure that the frame rate that you use on your MA is the same frame rate you use in your video editor? If they're different then the video will be choppy.
If you're going to publish at 1080 at 25 FPS, then record at 1080, 25 FPS. If that doesn't work let us know.
Skeeter Honey Posted at 2-22 18:27
Hi - the frame rate is the same and I guess the trouble is related maybe to the camera shutter and Fps, and then to export settings.
DJI Gamora Posted at 2-22 14:58
Hi Gamora - 4K Raw videos resized to 1080 same rate are OK; after combining 2 videos they are choppy; can you please advise on what settings to be used for post-prossesing and on what setup to record?
Any advise on what settings to record and how to post-process?
Most of the time this problem happens when you film in another framerate than you export (render) to.
So, for example, you film in 24 fps and render in 25fps.
That way your editor 'creates' (or drops) frames every xx frame and that causes stuttering.
So best is to film and render in the exact same framerate.
Please advise on the choppiness of this output, where I have been filming at 1/60 shutter plus ND filter, 4k 30fps, resized to 1080p 30fps and put alltogether:
