David_Harry
Tide Posted at 3-23 13:04
Thanks it certainly was a tasty treat.
Yes it is far from what real HDR is capable of. More like my silly experiment.
Hi.
It's not silly at all.
What you have proven is that with a bit of care you can mix the Pocket's 709 footage within a 2020 project.
In certain instances where you may have a HDR project with HDR footage but maybe you are missing a few shots. Then this example clearly shows that you can use a few pick up shots with the Pocket and mix them in.
It's always better to have something as opposed to nothing.
BTW. Please don't think that I was being funny with my previous response, I was just trying to clarify the distinction between 709 and 2020 dynamic range.
Here's another way of looking at it. An MP3 or AAC audio file can and do sound very good, although their sonic characteristics are not the best . If you have a project that's using 48Khz 24 Bit audio which is uncompressed, which would be typical for editing the audio of a video project and you use a MP3 or AAC audio file in it. The MP3 or AAC audio is padded out into the uncompressed work space but this doesn't increase the sonic quality of the original files and any further manipulation of those files will be limited to the original file's characteristics and can't be as manipulated as much as the same audio that originated as uncompressed PCM 48Khz 24 Bit.
Anyway, I thought your examples were great and thank you for taking the time to post and share your considerable efforts for the benefit of others.
Cheers,
Dave. |
