Lysak2003
Flight distance : 500052 ft
Ukraine
Think the main problem isn't in WB but right exposure value (EV). If you set camera settings manualy, it is quite reasonable to keep ISO at 100 and match shutter speed the way when EV is around 0,0. In that case, if you notice that image will be dark enough, you should reduce shutter speed at 1/3 step, or maybe even 2/3 step. But watch on sky on the screen. If some details in clouds will disappear and image became to bright in this area, you should increase shutter speed in back way. |
