eggbeater
Flight distance : 3502972 ft
I'm using all four CAN-bus accessories from DJI on a Cendence. Patch antenna, GPS unit, focus wheel and multilink. I just recently added the multilink now the focus wheel does not work unless I take one of the other CAN-bus accessories off line. Each CAN-bus device works on its own but not all together. With the GPS unit off line the focus wheel is intermittent with a flashing blue light. It would seem to be a power load that the CAN-bus circuit cannot support when all four devices are powered up at the same time. Has anyone else experienced this? This CAN-bus circuit is power for the patch antenna and I have become unconfortable with a loss of that power supply and a possible resultant disconnect with the aircraft.
