DJI Tony
Emanuelpr Posted at 2-26 17:58
lo que pasa que normalmente cuando la bateria esta al 15% automaticamente lading por baja bateria pero esta vez lo hizo con el 32%
Hi, thanks for the clarification. Have you tried to check the DJI Go 4 app if you've managed to set the low battery warning depending on your preference? If the aircraft disconnects on the remote controller, you may choose what will the aircraft do during this disconnection. As Nebuchadnezzar mentioned, you will have 3 option which are Return Home, Hover, and Auto landing. Please keep us posted on the latest progress. |
