Ronin S Motionlapse unuseable
910 1 2019-2-26
nickedw
Flight distance : 2177287 ft
Hi there, I've made repeated attempts at getting motionlpase to work properly and everytime the footage is unusable as in the attached test sequence.
Motion is not smooth or linear and as you can see the motion surges and delays.
I've tried different camera settings and nothing makes a difference, I'm using the built in tripod base on a solid surface that isn't moving.
I have the latest firmware the camera is perfectly balanced (GH4 with Olympus/M.Zuiko 12mm prime)
Is it just me? is it something I'm doing wrong? is there a solution?
Regards,
Nick
2019-2-26
Bin Gu
Hi, motion lpase is for taking photo; you can use motion control for taking video.
2019-8-2
