Crash (mavic air)
1020 4 2019-2-27
MAXDRONE77
Today I had a crash in a rock. My first crash... this happened like this:
Wanted to take a nice shot , the drone was just above me (25 m) then it started the automatic fly home, before I even could stop it , it crushed in the rock.
Thanks God just the propellers were broken at the end, I have changed the propellers and switched on again. The drone is hovering but when I try to fly up it does not go. It says that connect to Dji assistant 2 and recalibrate the back sensor.
Any experiences? Should I send to repair I have got the DJI refresh. ?
Thanks guys
2019-2-27
MAXDRONE77
Here is a picture what it says
2019-2-27
DJI Gamora
Hi there, thank you for reaching out and we're sorry to hear about the trouble. With regards to that. Yes you need to calibrate the Vision sensor using the DJI Assistant 2 you can download the software here https://www.dji.com/mavic-air/info#downloads then you need to connect your Aircraft to your computer. Aside from that, you may give a try as well to calibrate the IMU and the Compass, please keep us posted. Thanks!
2019-2-27
MAXDRONE77
Thank you for the quick response. I will do that as soon as I get home from my trip.
2019-2-27
DJI Gamora
MAXDRONE77 Posted at 2-27 10:39
My pleasure. If the issue persists, I'm afraid that you may start a case and send it in for diagnosis: https://www.dji.com/support thank you!
2019-2-27
