fans471029d5
Flight distance : 85449 ft
Poojap Posted at 2-28 10:01
Yes, but you are still initially being opted in. When it engages automatically, it has already done the damage to the framing of your shot.
Then there are instances where it won't engage until much later while you are recording. There isn't a reliable span of time or circumstance where you can (or even should have to) predict at which point you'll be able to cancel out of it after it has already engaged. It's not the biggest issue, but I think adding the option to disable it across the board would be useful to many people.
Ive given up using facetracking in selfie mode because it often just focuses on the background, frustrating i know. Also i need a clearer indication what its actually focusing on. |
