Canon 80D RSS-IR cord doesnt work after firmware update
2270 4 2019-2-28
fansb2b604da
After receiving my Ronin-S, the RSS-IR cord worked on the first try with my Canon 80D to start and stop recording. Since doing a firmware update, it has stopped working. I ordered the mini USB cord that should work with my 80D and it doesn't work either. I just can't figure out why it worked earlier on the first try and now it does nothing. Any ideas?
2019-2-28
djiuser_MD3iRPtZwORc
North Macedonia
You should change camera in create section in ronin app, change it to canon ;)
2019-2-28
Hi there, currently, RSS-IR cable is compatible with Canon 80D. With the RSS-IR cable, please point the infrared light to the camera's receiver vertically, the distance should be 1-3cm, you can use the small hook and loop strap to secure the RSS-IR control cable to the gimbal.
Please switch to Self-timer mode and ensure Bluetooth is turned off.
Then please select the Canon camera in Create--Camera Control of the APP.
2019-3-2
aaront_vj
DJI Mindy Posted at 3-2 01:58
I've done these steps with my Canon 80D and it's never worked.
Going on nearly a year since I've had my Ronin S.
Is there a way to trouble shoot my RSS port? or RSS-IR cord?
2019-6-25
bert hjva
Philippines
djiuser_MD3iRPtZwORc Posted at 2019-2-28 18:43
thank you thank you so much
2020-2-4
