DJI Pro Tech 2: Balance testing the Pan axis
1796 3 2019-3-1
DJI-Paul
Flight distance : 41159547 ft
China
I’m noticing a lot of new users not properly balancing their pan axis. This will result in a side to side wiggle when the gimbal is trying to stabilize the camera as you walk. To check whether your pan axis is balanced properly, take something like the included charger and place it under one of the tripod legs and hold the handle. With your other hand, go into the App and run the balance test. All 3 axes should be Excellent if properly balanced.
2019-3-1
DJI-Paul
China
You'll notice how little force it takes to spin the gimbal on the pan axis when it's sitting on a flat surface. When the Ronin-S is at this angle, it physically forces the pan axis into an offset allowing the balance test to properly check for balance.
2019-3-1
sky_makai
Flight distance : 1331283 ft
DJI-Paul Posted at 3-1 05:35
Thanks, Paul.
Question... Is there a better way to balance the pan axis for using the Ronin S inverted?
2019-3-8
djiuser_5OPW2ax0e1U9
Hi there
2020-8-9
