Aardvark
Flight distance : 384432 ft
If using the standard controller and a phone as display there can be disconnects caused by movement of the side cable where it plugs into phone. If this is the case then DJI Go 4 App' says 'disconnected' at top of screen this basically means that it has no communication to and from the RC via the USB connection. The RC itself would usually still be connected to, and controlling the aircraft.
I usually fly my Mavic Pro with an iPad on a mounting bracket and USB from display connected to lower full sized USB port at base of RC. For this to work the micro USB cable plugged into the side of the RC MUST be unplugged, otherwise lower USB port will be disabled. |
