JJB*
Flight distance : 12225059 ft
Hi N,
Only compass errors, but not as a low or high warning.
Batt temp will get higher during this 2m24s flight, so imo not the reason for falling out of the sky.
Max batt cells deviation 48mV, normal values.
No sudden large pitch and roll values at the end, so no bird-'crash' or fly into an obstacle etc.Or a bird hit your drone as it was hovering at 61 meters height for almost 60 seconds.
So the most likely reason for falling out of te sky is that he battery dismounted form your Spark.
But loosing a battery happens mostly in a rapid flight movement....so not sure about this.
* seeing the flight path in GE ; really bad luck, dropped almost on dry ground *
BTW first few seconds an OPTI fight, due to low GPS reception. After 9 seconds HP was recorded after some fwd flight, so HP was not set at take-off position.Bad? well, if disconencted and a RTH will land not where you are.... (this case HP just above water)
My advice is to take-off (if possible) > 20 meters away from the waterfront, just to be sure that if will RTH with dry feet.
Guess you will buy a new drone, go for the MA. (or buy my Spark)
cheers
JJB
