Schmooit
Flight distance : 1336581 ft
A CW Posted at 3-3 07:27
1) No. There is no requirement to pass any test in the UK providing it is, as you state, being used for recreational use only. If commercial then you will need to pass the UK CAA PfCO. Note that with effect from 30 November 2019 this will change and you will need to pass an on line test though presently not applicable.
2) Yes they are. They are the authority over UK airspace.
Agree with A CW, UAV Forecast app is also pretty good at giving an idea of the weather but also using the map functions show where nearby airfields are.
The new Airport boundary rules are 5KM but this is only an extension at the end of the runways for take off and approaches the 3km rule is still in place from the centre of the field I believe, (still best to stay clear to 5K unless you know what circuit the are running).
Also Isle of White is near me and has some nice places so does the south coast in general, on Isle of White there are 2 small airfields both GA type with no ATC (just ground to air radio for information not controlled that is) Bembridge, larger airfield close to the coast and Sandown a great little grass strip almost next door. Sandown (Isle of White Airport) does attract a lot of GA aircraft over a weekend and quite a few local training flights, circuit height is 1000 ft (normally left hand and there is a small walkway where the public watch us on final approach before we pass the threshold, if you want to fly near there just give them a call and tell them you might be flying nearby and they will let anyone in there circuit know you are operating close by but not above 400ft. (if its busy pop in to the cafe and have a cup of tea and watch the planes land (look out for a guy there with a Gyrocopter (its nuts! says me who fly Robbis!) in the summer there can be quite a few aircraft around the island. There are also 2 large radio transmitters so steer clear of those.
Best practice is do a little research first on some potential sites before you go and you cant go wrong also bear in mind privacy and land owners, they might have theire own rules, also there are quite few nature reserves and birds!. IOW can also be quite windy! South Wales is nice for flying, Oxford again has quite a few little airfields that can mean a lot of traffic in nice weather (that said as long as you stay below 400ft and always keep VLOS, keep an eye out and descend if needed there is no reason not to have fun!
Get practice in at low level first and always respect the wind and your battery life!
Have fun and enjoy PM me if you want any more info around Southampton and IOW ill see if I can answer!
