HH1
Flight distance : 73114 ft
Tony, I miss read your comment, and I apologize, of course you are right as to the two arm mounted lights being RED, and then the status light in the rear. Which I must thank you once again because, it brought to mind a semi wrong assumption on my part, and that is the RED and GREEN lights on a MANNED AIRCRAFT can be seen from both front and rear, which is not the case on fixed wing aircraft, however in a lot, if not all cases of lighting on HELICOPTERS the RED and GREEN can be seen from the ground, above the craft, and from front as well as rear of the craft, and this is what I was mentally referencing as I wrote the original post. The forward RED lights on the MPP must be turned on in the Flight Controller. |
