DJI Go 4 App (Android) 4.3.12/4.3.14
1869 5 2019-3-4
Bcor666
Flight distance : 437907 ft
Hi,
It seems that my english is not good enough to understand the text below.
Maybe someone of the admins is able to explain me the difference between the two version....
New in DJI GO 4 4.3.14
[New features]
Supports flight route planning, enabling users to set flight routes on the map and perform automatic flights for Mavic 2 Zoom and Mavic 2 Pro.
[Optimizations]
Improves stability of Editor.
New in DJI GO 4 4.3.12
[New features]
[Optimizations]
2019-3-4
jyc
Flight distance : 2273835 ft
Same thing, only different.
2019-3-4
GhostWolf010
Flight distance : 1118323 ft
Dji does not always tell us what they changed in the app. (Mostly they just give a vague description, even if they changed the whole app). So probably they did a f.up in the first, and repaired it in the second
2019-3-4
DJI Tony
Hi, thanks for the inquiry. The new version will be optimized the recent version to ensure the stability of this newly added feature while using the Mavic 2 Zoom and Mavic 2 Pro and avoid further problems when using it. Please let us know if you have other concerns. Thank you for continued support.
2019-3-4
Bcor666
DJI Tony Posted at 3-4 11:14
Hi, thanks for the inquiry. The new version will be optimized the recent version that to ensure that stability of this newly added feature while using the Mavic 2 Zoom and Mavic 2 Pro and avoid further problems when using it. Please let us know if you have other concerns. Thank you for continued support.
Hi, I have just tested the waypoints with the new Firmware for a few minutes:
- German version still have some Chinese characters
- waypoint with poi’s still not work soft like other apps (litchi,..)
2019-3-4
Valérien
Flight distance : 154137 ft
I wish to have:
  • Bouton key C1 / C2 to be a shift menu with interraction 3D boutons
  • the choise to activate or not the reloading of the mobile phone's battery.
  • more fun in sport mode
  • A french version to Android?
Good day, V
2019-3-11
