JJB*
Flight distance : 12132231 ft
Hi Pete,
Had a look at your flight.
The reason that HP was not set at take off point because of low GPS reception, just 2 bars.After atke-off distance start to indicate wiith 15, should be about 0 ofcourse.
During flight a warning "Weak GPS signal. Positioning accuracy may be compromised. Please fly with caution."
2 short moments flyinb in OPTI mode. (weak gps/reception)
But after while 20 sats and 5 bars for reception.
At 64 meter high and 38 meters away you lost connection, no errors before disconnection, so what happend?
1) batt dismounted from Spark, so it just dropped out of the sky.
2) after 3 seconds it should RTH, you did check the roof....
3) did a RTH to other position due to 15 meters off set HP <> take-off point.
So it must be close to your house somewhere....hope you will find your Spark.
cheers
JJB
