I've made a test flight with my Mavic 2 Pro inside my house with the obstacle avoidance disabled. However, I've noticed that the aircraft would stop ascending approximately 1m away from the ceiling. The DJI GO 4 app would pop-up a notification stating "upward obstacle detected".
Hi there, thank you for reaching out and sorry for some trouble. With regards to that actually, this is normal the upward sensor will still work even the obstacle avoidance is disabled. Best regards!
I would say that the downward obstacle avoidance should stay on due to proper landing detection, but the upwards should be disabled if the user disables obstacle avoidance. The issue is similar to the one Sebastian explains here at 4 min and 36 secs:
I'm concerned with 2 aspects:
1) If I'm flying indoors and the roof is about 2,5m tall, I will have the drone going only to about 1,5m due to obstacle avoidance, and that will still hit people. And when I mean people I mean my friends and family.
2) I'm especially concerned with flying under small roman bridges, the obstacle avoidance might lower the drone too much and hit some rocks or go into water.
ijd Posted at 3-6 06:44
I would say that the downward obstacle avoidance should stay on due to proper landing detection, but the upwards should be disabled if the user disables obstacle avoidance. The issue is similar to the one Sebastian explains here at 4 min and 36 secs: https://youtu.be/ekExmegBDA8?t=276
Maybe if it was stopping 10 or 20 cm far from a top obstacle or even better if its possible the operator to choose how far the drone will stop then it could be much better.
Is there any way to disable the upward sensor? I am a drone pilot for a police department. Our team practices clearing buildings with our drones from the outside. This week there was a particularly narrow winding stairwell with overhang that triggered the top sensor and did not allow the magic 2 pro to negotiate the stairwell. The mavic airs do not have that sensor and were able to negotiate just fine. I understand normally you would not want it disabled, but if anyone knows how please post.
Cover IR sensor with Aluminium Foil (Shiny side to IR) and you good to go. All IR light bounces back to sensor undisturbed and drone flies tight places
