Sparkz71
Flight distance : 24259 ft
Warriewoodlad Posted at 3-6 23:47
Final Update.
After much research and confusion, I gave up with Australian regulations and emailed DJI. In less than an hour I had my information. Why didn't I do that first up?
Try this link to the ACMA:
https://www.acma.gov.au/Industry ... -devices-fact-sheet
In short, it states (Maximum EIRP - radiation after antenna gain?):
500 milliwatts @ 2.4 Ghz with a minimum of 15 hopping frequencies (13 + 2, one at each end) ;
4 watts @ 2.4 Ghz with frequency hopping & digital modulation & a minimum of 75 hopping frequencies; (does not apply to 'normal' 13 ch (+2) wifi but still worth a mention)
4 watts @ 5.8 Ghz with frequency hopping & digital modulation & a minimum of 75 hopping frequencies.
Re the official Spark Specs (as published online):
The Aircraft @ 2.4 Ghz is FCC 25 dBm, CE 18 dBm, SRRC 18 dBm or MIC 18 dBm
The Aircraft @ 5.8 Ghz is FCC 27 dBm, CE 14 dBm, SRRC 27 dBm or MIC -
The Remote Controller @ 2.4 Ghz is FCC 26 dBm, CE 18 dBm, SRRC 18 dBm or MIC 18 dBm
The Remote Controller @ 5.8 Ghz is FCC 28 dBm, CE 14 dBm, SRRC 26 dBm or MIC -
14 dBm is 0.025 watts
18 dBm is 0.060 watts.
25 dBm is 0.316 watts
26 dBm is 0.390 watts
27 dBm is 0.500 watts
28 dBm is 0.630 watts
Regardless, double the power does not mean double the distance. I forget the equation exactly, but double the power may only increase distance by 25%. So you may need 4 times power to double the distance. Something like that - I forget the exact equations required to solve RF issues in my head. I just use a program to solve these things. Line of Sight is the key. I can pump 100 watts out, but if an mountain or obstacle is in the way, I am no better than using 0.5 watts.
Good luck.
