Can I Share Waypoints 2.0 Task Library between devices
7763 19 2019-3-5
Nermie
Flight distance : 56795 ft
I have been using the new Waypoints 2.0 feature in the latest update of the Go4 app. I have created a waypoint mission and saved it to my task library on my Iphone. However I do not seem to be able to access these task library records when I use the same app on my Ipad. I have shared all flight logs via my dji account and the cloud, but the task library does not seem to be sharing.
Is it possible to share task Libraries between devices? If so, what can you suggest I am doing wrong?
2019-3-5
saviour
Flight distance : 604203 ft
No you can't.
2019-3-5
Nermie
Thank you,
Hopefully this is something that DJI will address in future updates.
2019-3-6
CyFA
Flight distance : 1372369 ft
Cyprus
Nermie Posted at 3-6 00:18
Thank you,
And thats why i love Litchi but ... will not work with the smart RC
2019-3-6
DAFlys
As you are on iPhone you can copy the waypoints.db file through iTunes between devices.   You can also edit this file with an sqlite browser.
2019-3-6
Nermie
DAFlys Posted at 3-6 07:15
thanks for that tip
2019-3-6
DJI Gamora
Hi there, thank you for reaching out and we really admire you using the DJI Product. With regards to that, as of the time being, we don't have the option yet or way to transfer the saved planned waypoint to a different device. Thank you for your consideration.
2019-3-6
UNsyncED
Flight distance : 1083392 ft
Have you tried DJI GS Pro?
2019-3-7
Nermie
UNsyncED Posted at 3-7 00:27
Yes, I was using this prior to Waypoints 2.0 being released on Go4. My undertsanding is that GS Pro only works on an iPad, so sharing between an Ipad and a iPhone is not an option. I have not yet had a chance to compare the updated GS Pro with the Go 4 app.
One thing I have noticed is that the waypoint heights on the new Go4 app seem to be limited to a Min of 2.0m. I know this as I was trying to get the drone to fly under a bar that was around 2.0m in height. Whilst i flew the drone first and recorded the lower waypoint heights (e.g 1.0 m), the program reverted when flying to 2.0 m and this nearly caused a crash. I could not edit the waypoint down to below 2.0 m.
2019-3-7
UNsyncED
Nermie Posted at 3-7 01:13
The minimum height limit sounds frustrating.
I own a P4 and M2, and if I use an iPad, I can share the route with each device.
I can’t advise if GSP allows a minimum height below 2m. Might be worth testing.
An iPad Mini can fit on both an P4 and Mavic style Controllers.
2019-3-8
Nermie
UNsyncED Posted at 3-8 01:02
Today, on DAFlys suggestion above, I shared the waypoints.db through iTunes although I haven't had a chance to test it yet. I did note however that some of the Waypoint altitude heights were just under 1.4 meters. This was as recorded during flight. When I was actually flying the other day when I recorded these waypoints, I noticed I could not change one to below 2.0m. I am thinking that the min height is probably in non metric, ie inches or feet. Because of this, altering a metric measurement does not allow smaller increments, hence 2.0m because 1.0m would be below the limit. If 0.1m increments were allowed, maybe i could change it a bit lower.
The actual number recorded was 1.39999997615814m which is 55.11 inches or or 4.593 ft so it is neither exact for metric or imperial.
2019-3-8
DAFlys
Nermie Posted at 3-8 01:21
If you open the waypoints.db in https://sqlitebrowser.org/ you can set any value,  I dont know what would happen when the app reads the value though.
2019-3-8
edwinnaar
I'm actually working on a little tool that currently works on Mac OS but I might make a native Win10 version for it, once I'm done.
In my app I will be able to join and edit waypoint databases. When a tablet is connected it should detect and find the waypoints file automatically. This should also work when a smartcontroller is connected.
I'm not done with it yet. But I'll keep you guys posted.
2020-4-8
Nermie
Thanks edwinnaar, I look forward to your results.
2020-4-8
fanscf06b8d1
Brazil
edwinnaar Posted at 4-8 00:00
Hi! any update about this tool to Win version?
2020-7-4
fanscf06b8d1
Brazil
Hi! Somebody found a way to copy waypoints.db on Android device? (I really never will understand why DJI make features like WAYPOINTS without basic options like INPUT GPS COORDINATES and save off line or share database... And the most incredible thing: we need torn on Mavic to edit waypoints... DJI could ask to Litchi where find developers to make basic features... and respect their clients, because we pay much money and I think we deserve a great App)
2020-7-4
djiuser_9b0hUjjlbYyt
Flight distance : 20653 ft
edwinnaar Posted at 2020-4-8 00:00
Any progress on this?
2021-11-20
2021-11-20
AVInteractive
Flight distance : 194495 ft
DAFlys Posted at 2019-3-6 07:15
Not sure when you posted this, but thanks that worked :-)
2023-8-24
DAFlys
AVInteractive Posted at 8-24 09:04
Wow.  that was a post from 2019.  Pleased it helped you out.
2023-8-24
