Lightbridge 2 Ground Unit won't link with latest Air Unit firmware
2044 2 2019-3-5
Jbonnett
Flight distance : 125807 ft
Hi All,
Ground Unit won't link with latest Air Unit firmware, is there a way to update the Ground Unit? DJI Assistant 2 will not recognise it if that is the case.
Any help is much appreciated,
Jamie
2019-3-5
jhc
Flight distance : 790761 ft
Hey this helps some people but not all hope it helps you,  from another thread in the M600 forum;
"I fixed my slave connection problem by downgrading both side of the Lightbridge. (Lightbridge air unit trough DJI Assist 2 back to V1.1.60 and Both Lightbridge controllers using DJI GO app on an Iphone/IOS device.)
the tricky part is downgrading the Lightbridge controllers. Crystalsky can not apply the downgrade and/or upgrade on the controllers because it's an Android device. But if you try to connect an IOS you will get an option to upgrade, and if you already upgraded the controller firmware to 1.2.40
you will need to downgrade it back to 1.2.10.
You can do this by touch and holding the three little horizontal lines on the right corner of the main page of Go app on IOS for over 5 seconds . it will take you to a hidden menu that allows you to downgrade the controller Firmware. "
2019-3-26
ckk.post
Denmark
when I do so
it writes in the app
of I have to update the air unit
then I do so I lose the connection to the controller
what happens to the updates
Dji get it fixed now
It should be an improvement but now a problem
2019-4-14
