Aardvark
Flight distance : 384432 ft
georgios87 Posted at 3-6 08:30
Thank you very much! I used an iPhone 6S and an iPad mini 2. Same in both, the radar chart or OA display as I understand from Labroides most people might refer to, never shows. Obstacle avoidance is enabled and all sensors and options enabled. Also, I get no system errors at all, regarding vision system or need for calibrating it but clearly from hover tests I have made the front or bottom sensors do indeed seem to be inactive. I even get the obstacle avoidance icon appearing as "white" and not greyed out as it would be if OA was off. I think its a lost cause trying to calibrate the sensors on this old P4 firmware I don't remember the exact version but I remember it says the firmware was last updated in June of last year!!! I will update the firmware as soon as I can access a pc again and I will keep you guys posted. Once again, I am sorry for lashing out at Labroides, but I really thought he was trolling me from a point on (anonymity of the internet and trying to make meaning of written text can cause misunderstandings of context many times), never meant to come out as a smug sob, I am the exact opposite and I am willing to learn more and more since I believe nobody is perfect. I must say that I tried all methods I describe above to fix the problem and exhausted all info I have found online on the matter or in written manuals or this and other forums before posting my problem here, the last thing I would want is to waste anybody's time with stuff that has been answered before. I believed I made myself pretty clear to him about having all sensors enabled but I guess because of the fact that I am not a native english speaker some of that probably got lost in the translation? anyhow, just wanted to clarify a few things since I am new in this forum and don't want to leave a bad impression
"I used an iPhone 6S"
I use an iPhone 6S plus with my P4, which displays the 'radar' for the front Obstacle Avoidance sensors.
Although this may sound obvious, check that the 'display radar chart' is enabled in DJI Go 4 otherwise it will not display. Also check that 'Enable Vision Positioning' is enabled in the Advanced Settings section of the Visual Navigations Settings menu. If the OA screen display icon is white it means there is sufficient light for it to work, and OA is active, otherwise it turns red when OA is disabled or insufficient light.
As well as updating firmware to .0700, the RC also needs to be updated to V1.9.3 otherwise there will be problems with display.
See screen grab from my 6S plus:-
Also there shouldn't be any problems in calibrating the VPS on the P4 with the last release of firmware from January last year, as production of the P4 itself ceased on April 30th 2017.
From the P4 release notes:-
2018.01.24
Overview • Aircraft Firmware: v02.00.0700 • Remote Controller Firmware: v1.9.3.0 • DJI GO 4 App iOS: v4.1.22 • DJI GO 4 App Android: v4.1.22
