Camera issue
626 8 2019-3-6
mathiashoffner
Flight distance : 987336 ft
Denmark
Got a issue with my camera. When ever I power it off, the camera tilt to the left. YouTube link: https://youtu.be/VUmbgBwqUgU
Any ideas? The drone is brand new...
2019-3-6
CyFA
Flight distance : 1372369 ft
Cyprus
So does mine but does it matter?
As long as it stays straight after initializing and in flight ;)
2019-3-6
DJI Gamora
Hi there, thank you for reaching out. With regards to that. Actually, it just normal since the Aircraft is off and the gimbal doesn't have a power that's why the gimbal can move freely. It will be only centered if the Aircraft is on and the gimbal camera will stabilize itself. Thank you for your support.
2019-3-6
mathiashoffner
Denmark
DJI Gamora Posted at 3-6 08:37
Hi, but I know a lot who owns a Mavic 2 pro, and there’s doesn’t tilt to the left when powered off.. what is the reason of that?
Thanks
2019-3-6
mathiashoffner
Denmark
mathiashoffner Posted at 3-6 08:41
Thanks
Because normally when you turn the drone off, it will still keep stable, (unless you touch it) my tilt to the left?
2019-3-6
DJI Gamora
Thanks
Ok, one of the reasons, the gimbal don't have the supplied power since the Aircraft is already turned off and the gimbal can move freely so this seems to be normal. Thanks!
2019-3-6
mathiashoffner
Denmark
DJI Gamora Posted at 3-6 14:19
Im not sure if you understand me.
This is my drone
Here you can see it tilt to the side, which isnt normal.
Here is a normal one, where it dosent tilt
Why is there this clearly differents
2019-3-6
Eric13
Flight distance : 13982031 ft
This is not an issue. Gimbals always 'relax' after being powered off.
You should only be worried if it is off level when powered on.
2019-3-6
M2Wair
Flight distance : 1192231 ft
Yup completely normal
2019-3-7
