Jholder
Flight distance : 108173 ft
I am working on a program at work that we are testing using drones for some tasks. We recently purchased:
1 Mavic 2 enterprise zoom, with a Crystal Sky
1 mavic 2 dual, with Crystal Sky
I recieved the Zoom yesturday and have not been able to get it to work. Have not recievved the Dual yet...
1. At first setup it would not activate, I would get the error server error 500
2. I next atempted to use Mavic Assistant 2.
- This only set the firmware on the Mavic to V.1.00.000.
- I also updated the RC to V1.00.0300
Here is now the problem:
Every time I try to connect to the drone the CS says that a new firmware version is availble 'v1.00.0300'. It will start to download and install, but half way through the CS will flicker and go to the screen that has you choose DGI Go or DGI Go 4, (both of these are the latest version also) then after a while nothing happens. If I go back to the App it all starts again, new firware availible etc.
I have also tried downgrading the RC to V.1.00.000, this does not help, the CS says the RC needs to be updated.
When I connect the drone back to the computer, Mavic Assistant 2 shows the only firmware availible is V.1.00.000 but I can not use the drone becouse the CS wants me to update to V1.00.0300
Help I am stuck in a loop.
