HereForTheBeer
Flight distance : 5381368 ft
Oracle Miata Posted at 3-16 06:47
It’s quieter then before, but not even close to M2P quiet. I would say closer to my Spark, but still a bit louder. Given how loud it was before, I deem it acceptable. The flight characteristics are a bit odd though...
just noticed you mentioned flight characteristics.... what changed? i would say for me, nothing really changed, if anything its more stable and more linear.. specially with wind, less movement of the aircraft and more leaning into it gently to counter it that was something i noticed too... not perfect still gets pushed around a bit when it doesnt anticipate changes, but its better than stock props.. it flies just as fast, stops little quicker, when flying into the wind in sport mode, not knocking end of the gimbal as much as stock props interm sof roll pitch, its more shallow so less gimbal knock from that as well.. uhm..yea other than that not much differant.
when i say gimbal knock what i mean is it nailing the end of the gimbal limit and being pushed forcefully around usually once aricraft evebts out, the gimbal either slow to zer back out comparitively to aricraft or it stays wher it was pushed... stock props have an issue with forward gimbal knock in sport more when fighting the wind.. they knock end of the gimbal limit then when aircraft settles the pitch of the gimbal is usually no zeroed back exactly wher eyou had it and few degrees short or very slow yo zero back out after settling. havent experianced this with these new props....even if im at end of the gimbal limit the gimbal not being knocked around
