Finally the quiet stealth Master Airscrew propellers available !
12345
24157 167 2019-3-8
WayneMHK
Flight distance : 694728 ft
I've not had an issue, and think that for my use they are a bit quieter and flight time is slightly increased.  The only issue I have is that the sound appears to attract birds!  Maybe I'm paranoid but I've never had that problem before.
2019-4-25
Filipok
I received mine yesterday. They live up to the hype. Buy them.
2019-7-31
Filipok
Oracle Miata Posted at 3-17 05:03
Posted by a poster on another site:  quite interesting.
The MAS rotate slower than OEM's. But the same amount of air must be moved for hovering over the ground. As a result, the MAS needs slightly more amps, and this affects the stability of the supply voltage for the motors. The motherboard / Firmware knows the normal conditions for all modes of operation, so a voltage drop is a different condition and this is signaled to the operator with a warning message on the screen. There will certainly be some reserve, but there will be an over-current load on the engines, just like flying against strong winds or carrying extra load. Flying in Sport Mode can also cause this warning message.
The suggested gain settings are on the MAS website for Mavic Air. They recommend that you adjust the gain to match the improved efficiency of the props.
2019-7-31
Oracle Miata
Flight distance : 3759829 ft
Filipok Posted at 7-31 06:32
Yeah, when they went to version 2.0 they actually included a card in the box with recommended settings...
Wait, you have the new Spark ones?  I got mine yesterday.  To me, they don't make nearly the difference the MA ones do.  Especially pitch.
2019-8-1
Skeeterhead
I’m new to this amazing forum. Does usage of aftermarket propellers void the DJI warranty?
2020-2-12
Punchbuggy
Flight distance : 483166 ft
Skeeterhead Posted at 2-12 14:41
I believe that the official position will be Yes. However, if you have an issue with the craft and you return it to DJI for analysis of the onboard data, and it can be determined to be an unrelated fault, I also believe that DJI would do the right thing.
2020-2-13
aroaro
Flight distance : 853681 ft
Poland
Watch out for these propellers!
The drone did not fall, but it was close enough.
  All other causes of failure eliminated. All Master Airscrew stealth settings are well set in menus.
2020-2-14
Skeeterhead
Punchbuggy Posted at 2-13 12:19
Thank you for your kind reply. In this case I believe discretion is the better part of valor.  I will wait until my warranty expires.
2020-2-19
12345
