Filipok
Oracle Miata Posted at 3-17 05:03
Posted by a poster on another site: quite interesting.
The MAS rotate slower than OEM's. But the same amount of air must be moved for hovering over the ground. As a result, the MAS needs slightly more amps, and this affects the stability of the supply voltage for the motors. The motherboard / Firmware knows the normal conditions for all modes of operation, so a voltage drop is a different condition and this is signaled to the operator with a warning message on the screen. There will certainly be some reserve, but there will be an over-current load on the engines, just like flying against strong winds or carrying extra load. Flying in Sport Mode can also cause this warning message.
The suggested gain settings are on the MAS website for Mavic Air. They recommend that you adjust the gain to match the improved efficiency of the props. |
