store drone with propeler attached
731 9 2019-3-10
Vinniez
Flight distance : 2106204 ft
Indonesia
hello there ,
Just want to ask your experience  , is it safe to store our mavic 2 with propeller attached in the bag or case when travelling ?
thanks
2019-3-10
Matman
Flight distance : 644669 ft
Yes, perfectly fine..
2019-3-10
DJI Paladin
Flight distance : 318 ft
Hi Vinniez, thanks for reaching out. You can leave the props on when storing it. If the propeller is scratched, bent, or damaged kindly replace it immediately. Thanks for your support.
2019-3-10
rwynant V1
Flight distance : 4842277 ft
Just be sure there is no load on any part of the propeller, and all will be fine as stated.
Randy
2019-3-10
Indio
Flight distance : 303373 ft
Austria
best solution
https://www.amazon.com/PGYTECH-P ... ories/dp/B07GLLYZPC
2019-3-10
HH1
Flight distance : 73114 ft
Vinniez  - I take them off, less chance of them getting damaged, and then they are not on if you put the battery in first, which I do last.  But, it is up to you and the conditions under which you transport or store.  Good flying
2019-3-10
akozc
Flight distance : 2019951 ft
Its ok to leave them on ,just try to buy pgytech propeller secure fasteners which will keep the propellers safe and sound during off use time.
2019-3-10
Lucas775
Flight distance : 50642090 ft
No reason to remove them when traveling.
2019-3-10
AlphaFlightNW
Flight distance : 784265 ft
I do leave mine on, though I have bought restrainers so that they wont flop about when trying to fit them into a bag/case. Especially with the M2's.
2019-3-10
Vinniez
Indonesia
thanks all for your feedback..
2019-3-12
