Flight Logs Showing wrong date
1234
15021 132 2019-3-11
Kropserkel
Flight distance : 2472339 ft
+1 This exact scenario (equipment and dates) happened to me as well.
2019-4-28
Billboyheritagesurvey
Flight distance : 232306 ft
Kropserkel Posted at 4-28 14:59
Kropserkel : where on the planet are you?. It apears this problem is time zone specific. So far we have recorded failure in USA, Finland, Netherlands & Germany.
2019-4-28
DJI Susan Posted at 4-3 02:07
Hi All,
Sorry for keeping you waiting. I just got an update from our engineers that they will fix the date issue in the next firmware update.
We'll release as soon as it is ready. Currently, you may turn off the automatically obtain network time feature and manually modify the time to the correct time. Appreciate your support and patience.
Hi there. I need to let you know the date/time issue is not completely resolved by the 4.3.16 update  for all time zones. In the UK it seems to be OK but it appears a problem persists in some time zones. So far the forum has recorded failure in USA, Finland, Netherlands & Germany.
It looks like an error in the GMT offset in some time zones.
We are looking for acknowledgement from Admin this is recognised as a problem for DJI to solve.
2019-4-28
ff22
Billboyheritagesurvey Posted at 4-28 23:40
Well, not only GMT but mine has crossed the International Date Line backward a few hundred times as it shows files with dates in June 2018, yes, 2018.  Both pics, videos and LOG/txt files are in 2018.
2019-4-29
fans51d5d379
Flight distance : 1551909 ft
I too have incorrect date information. This post is 05/02/2019 and I last flew mid April. Last flights after March 2019 show in September and October, 6 months in the future. What gives?
2019-5-2
fans51d5d379 Posted at 5-2 08:29
If I'm reading this right the last flights were on the 9th and 10th of April 2019. Is this a problem? You may be misreading the day/month /year order!
2019-5-2
ff22
Billboyheritagesurvey Posted at 5-2 12:35
Well, I know 2018 was wrong for the files created last week.
2019-5-2
ff22 Posted at 5-2 15:06
I was in reply to fans51d5d379 post at #125. Do you hvae a screen grab of your error. We still have no ack from DJI on this btw.
2019-5-3
Mullazman
Flight distance : 1160968 ft
Me too, for a year and a half now.. no help on the matter.
And when I try and get support from DJI ->
2019-5-6
mike9887
Flight distance : 220292 ft
Mav505 Posted at 3-27 16:26
Mine shows "Map Loading" as well.. also how is my top altitude -68.7 ?
[view_image]
Wow -- impressive (not) altitude     My flight records only show my Mavic and seem to be okay but won't sync with my Inspire flight records.
2019-6-30
fansa3ce9021
Flight distance : 14278 ft
Problem is NOT solved. My flight on 2020 October 11 with up-to-date firmware on Smart Controller and DJI Mavic 2 Pro are all recorded for 2017 September 14.
2020-10-13
Jordan146
Same here on a DJI Mavic 2 Pro and it has nothing to do with SD card, type of Phone or Phone time settings (I used multiple SD card from different brands and 3 different iPhones all set to the timezone of the country I was in). I travelled in 3 different countries with different timezone and the timestamp is always correct on the photos but never on the videos. First, when I moved from France to New Zealand, the timestamp of videos was ahead of 12h (the timezone difference between the 2 countries). Then, we changed hour in New Zealand and the timestamp of videos offset by 11h (the new timezone difference between the 2 countries). I then moved to Samoa and the timestamp of videos was ahead by only one hour now (the timezone difference between New Zealand and Samoa).
It's been a recurrent issue noticed by many DJI drone users that doesn't seem to be solve by DJI. I hope my comment will help you solve this problem as it seems to be a complex one depending on the previous country you visited, the new you are in and the timezone difference between them. However, I still don't understand how the software can timestamp photos correctly but not the videos?!
2020-10-31
digibud
Flight distance : 7820246 ft
Here it is Nov 2021 and this is still a thing. I found this link after searching for help with all of my logs being one day off. Now I know I cannot change them and this problem will never (apparently) be fixed. What a foolish failure of programming.  I have never changed times zones or anything. New user. It's not practical for me to take the time to manually input the date and time. I often fly, drive to another area make several flights, etc. Stopping to input dates and time...impractical. Sad.
2021-11-19
1234
