Sign in required to fly...
585 3 2019-3-11
KJOOS
Flight distance : 153192 ft
Denmark
Hi!
I experience that I have to login to my Smart Controller (DJI GO 4) to be able to fly. I can't bypass the login screen, meaning that I can't fly at all.
It tells me that I do not have any Internet connections. - That's true, because I can't, as many others, connect the Smart Controller to my home wireless network
I have tried everything - I think. I have upgraded the firmeware to 1.0.400 via DJI Assistent. Before that I have reset the controller completly.
So, any suggestions, how I can get an internet connection to work? Can I e.g. connect via a cable?
Please HELP!
Kinf Regards,
Kristian
2019-3-11
DJI Tony
Hi, we're sorry to know about this situation. Please follow the instruction below to possibly fix this matter and you could also download the DJI Assistant 2 using the link below. Kindly keep us posted on the latest progress.
1. Connect to another Wi-Fi. (If possible)
2. Change the current Wi-Fi's SSID and try to connect to it again.
3. Make sure to enter the correct password when connecting to a new Wi-Fi."4. Upgrade the controller's firmware to the latest version and re-connect it to a Wi-Fi.
https://www.dji.com/mavic-2/info#downloads
2019-3-11
KJOOS
Denmark
I got it to work simply connecting to another wireless network - at my work.
What is the requirements for connect to a wireless network? Are there any known issues with wireless networks?
2019-3-11
DJI Tony
KJOOS Posted at 3-11 22:29
Hi, thank you for the updates. We're glad to know that you've managed to solve this situation. There are no requirements for connecting the Smart remote controller to the wi-fi, however, this may encounter due to that you entered the wrong Wi-Fi password during the activation, so even if you enter the correct Wi-Fi password the next time, the connection will still fail. Having said that, this is not a known problem, however, this is a normal phenomenon. Please let us know if you have other concerns. Thank you for continued support.
2019-3-12
