pmshop
Flight distance : 8073271 ft
ChrisJG Posted at 3-13 05:59
Thank you!
Im tempted to upgrade to an Air for the longer battery life, if I get it wrong and Sparky is taking a bath!
Naw, you will do just fine!
If you plan to skim the water for effect, try to stay at least 20' off the water.
But if you go lower, be prepared to gently raise the craft because it will tend to lower itself.
The visual positioning system gets confused with the reflections of water and thinks it is higher than it is so it lowers itself.
Hard to determine what height that will happen at because angle of the sun affects that too.
But if you to an across the middle flight between the water and the bridge, you will be OK. |
