DJI Tony
Hi, thanks for the inquiry. If you've used this said device during your flight with DJI Phantom 4 Pro, you should be able to locate the cache files in the DJI GO 4 application under"Editor" section which are in the lower resolution. However, if you need the original files then you may need to use a card reader and export the SD card files into your computer then transfer it to your tablet for you to be able to play it. Hope that his information would help you in regards to your query. |
