osmo mobile 2- calibrite pan motor
1976 5 2019-3-13
zion183
Flight distance : 36 ft
Israel
Hello,
I have a osmo mobile 2 that works fine but when I press the M button, the pan motor not straight, I tried to calibrate the stabilizer and everything was good but not yet straight, always turning right,
Is there an option to re-determine its center point?
best regards
2019-3-13
DJI Gamora
Hi there, thank you for reaching out and we're sorry to hear about the trouble. With regards to that. Before turning on the Osmo mobile 2 make sure you properly balance it horizontally. You may check this video tutorial and use as your reference. Best regards!
2019-3-13
zion183
Israel
I made the balance but the problem was not solved
2019-3-13
psiman
Brazil
Mine was working fine but now when I pan right or left it goes up and down. I tried to delete the app, recalibrate but nothing works. Is there any way to do a hard reset?
Firmware: 2.2.0.30
2019-3-18
Carlojazz
psiman Posted at 2019-3-18 20:26
Firmware: 2.2.0.30
I have the same problem, tried to find the way to reset it or reload the firmware but nothing found
2-19 19:48
DJI Tony
Carlojazz Posted at 2-19 19:48
Hello there. Sorry about the trouble. Please check whether the mobile phone is parallel to the mobile phone holder Also check whether the mobile phone holder is parallel to the tilt axis arm and then perform auto calibration with DJI GO. Have a nice day.
2-20 00:04
