Peripecias
DJI Mindy Posted at 4-22 20:59
Hi there, can you please help export the logs for further analysis? Please upload to Dropbox or Google Drive and post the link here.
Windows:C:\Users\xxxxxxxx\AppData\Roaming\DJI Assistant 2\RONIN\log
Mac: ~/Library/Application Support/DJI Pro Assistant For Ronin /Contents/DJIApp
Hi DJI Mindy,
I tried to upgrate and downgrate the firmware of my Ronin-S (V1.9.0.80, V1.8.0.70, V1.7.0.60 & V1.1.0.0), I change USB cables, change the USB ports, take out the RSS-IR cable or leaved in, restarted the gimbal few times, tried with the gimbal on and off, tried in a Windows 10 pro 64bit and in a MacBook Pro with MacOS High Sierra v.10.13.6, I also downloaded the latest versions of the DJI Pro Assistant app in the PC and Mac and in the app of the iPhone. Both machines and phone are connected to internet (Wifi and bluetooth) having in both cases pretty fast connection.
The focus wheel keep flashing in red and when I start the up/down grade, this light slows down but continuing in red. The 1, 2 & 3 green mode lights turned in in red flashing for few times until the gimbal engine stops and those lights turned off definitely.
I have the gimbal for more that 6 months and I using often having only the tilt problem in it but I'm speaking with the DJI Support and it was looking that it was planning to be sorted out soon. But since yesterday that I tried to upgrade the firmware, the bluetooth in the gimbal stopped and I can not sincronise from the phone, PC or Mac anymore.
It's quite frustrating that there always is something going on with the gimbal.
Here you have the LOG to have an eye on it.
Thanks
[21:35:27.998][DJIWebFileGetter ] [OnFinish]reply statusCode=201
[21:35:28.357][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:30.161][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:30.162][DJIServerApi ] [ApiV2UserUsertype]url=https://mydjiflight.dji.com/api/v2/user/user_type||device_token=9b538302-dc05-4b33-8a6a-565285158080
[21:35:30.163][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:31.110][DJIWebFileGetter ] [OnFinish]reply statusCode=201
[21:35:31.110][DJILogin ] user type:
[21:35:44.809][DJIIdentifierMgr ] Device Arrive COM3
[21:35:44.809][DJICmdIo ] open COM3
[21:35:45.010][DJISerialIo ] Open COM3 success!
[21:35:45.010][DJIIdentifierMgr ] open device succeed
[21:35:45.104][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.40 ], App
[21:35:45.104][DJIDeviceMgr ] device service ready! COM3
[21:35:45.109][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, activated
[21:35:45.229][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:50.419][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, activated
[21:35:50.465][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, activated
[21:35:50.514][DJIUpgradeMgr ] ServiceUrl : https://mydjiflight.dji.com/links/links/hg700
[21:35:50.514][DJIUpgradeView ] userType :
[21:35:50.523][DJIDeviceInfoEnumera] 5% 1/17 GCU(7)
[21:35:50.524][DJIDeviceInfoEnumera] 11% 2/17 Battery(0)
[21:35:50.529][DJIDeviceInfoEnumera] 17% 3/17 Roll(2)
[21:35:50.529][DJIDeviceInfoEnumera] 23% 4/17 Yaw(3)
[21:35:50.658][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:50.659][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:51.028][DJIDeviceInfoEnumera] 29% 5/17 Focus_Wheel(1)
[21:35:51.157][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:51.158][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:51.330][DJIDeviceInfoEnumera] 35% 6/17 IMU(0)
[21:35:51.330][DJIDeviceInfoEnumera] 41% 7/17 Pitch(1)
[21:35:52.540][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Bluetooth(7:1)
[21:35:52.540][DJIDeviceInfoEnumera] 47% 8/17 Bluetooth(1)
[21:35:52.540][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD(5:6)
[21:35:52.540][DJIDeviceInfoEnumera] 52% 9/17 LCD(6)
[21:35:52.540][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD_flash(5:3)
[21:35:52.540][DJIDeviceInfoEnumera] 58% 10/17 LCD_flash(3)
[21:35:52.540][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: On-board Mount(5:0)
[21:35:52.540][DJIDeviceInfoEnumera] 64% 11/17 On-board Mount(0)
[21:35:52.550][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Handler(5:4)
[21:35:52.550][DJIDeviceInfoEnumera] 70% 12/17 Focus Handler(4)
[21:35:52.550][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: RC Handler(5:5)
[21:35:52.550][DJIDeviceInfoEnumera] 76% 13/17 RC Handler(5)
[21:35:52.550][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: EXT_GPS(5:1)
[21:35:52.550][DJIDeviceInfoEnumera] 82% 14/17 EXT_GPS(1)
[21:35:52.550][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Motor(31:5)
[21:35:52.550][DJIDeviceInfoEnumera] 88% 15/17 Focus Motor(5)
[21:35:52.550][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Iris Motor (31:6)
[21:35:52.550][DJIDeviceInfoEnumera] 94% 16/17 Iris Motor (6)
[21:35:52.560][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Zoom Motor(31:7)
[21:35:52.560][DJIDeviceInfoEnumera] 100% 17/17 Zoom Motor(7)
[21:35:52.560][DJIDeviceInfoEnumera] GCU (5 :7) Ldr : 01.00.03.00 App : 01.00.06.40
[21:35:52.560][DJIDeviceInfoEnumera] IMU (4 :0) Ldr : 09.01.00.17 App : 00.01.10.15 GB09
[21:35:52.560][DJIDeviceInfoEnumera] Pitch (4 :1) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:35:52.560][DJIDeviceInfoEnumera] Roll (4 :2) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:35:52.560][DJIDeviceInfoEnumera] Yaw (4 :3) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:35:52.560][DJIDeviceInfoEnumera] Bluetooth (7 :1) device no reply, request timeout!
[21:35:52.560][DJIDeviceInfoEnumera] Focus_Wheel (6 :1) Ldr : 01.00.00.00 App : 02.02.00.07
[21:35:52.560][DJIDeviceInfoEnumera] LCD (5 :6) device no reply, request timeout!
[21:35:52.560][DJIDeviceInfoEnumera] LCD_flash (5 :3) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] Focus Handler (5 :4) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] RC Handler (5 :5) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] Battery (11:0) Ldr : 00.00.00.01 App : 04.73.05.07 HG700BATTERY
[21:35:52.561][DJIDeviceInfoEnumera] EXT_GPS (5 :1) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] Focus Motor (31:5) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] Iris Motor (31:6) device no reply, request timeout!
[21:35:52.561][DJIDeviceInfoEnumera] Zoom Motor (31:7) device no reply, request timeout!
[21:35:52.561][DJIServerApi ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700
[21:35:52.755][DJIWebFileGetter ] [OnFinish]reply statusCode=302
[21:35:53.140][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Gimbal(0) higher, Cur: 00.01.10.15, Dst: 00.02.10.89
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Gimbal(1) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Gimbal(2) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Gimbal(3) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Center_board(7) higher, Cur: 01.00.06.40, Dst: 01.00.06.59
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Remote_radio(1) equal , Cur: 02.02.00.07, Dst: 02.02.00.07
[21:35:53.169][DJIFirmPackListRefre] 1.9.0.80 Battery(0) equal , Cur: 04.73.05.07, Dst: 04.73.05.07
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Gimbal(0) equal , Cur: 00.01.10.15, Dst: 00.01.10.15
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Gimbal(1) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Gimbal(2) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Gimbal(3) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Center_board(7) equal , Cur: 01.00.06.40, Dst: 01.00.06.40
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Remote_radio(1) equal , Cur: 02.02.00.07, Dst: 02.02.00.07
[21:35:53.169][DJIFirmPackListRefre] 1.8.0.70 Battery(0) equal , Cur: 04.73.05.07, Dst: 04.73.05.07
[21:35:53.169][DJIFirmPackListRefre] 1.7.0.60 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.68
[21:35:53.169][DJIFirmPackListRefre] 1.6.0.50 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.66
[21:35:53.170][DJIFirmPackListRefre] 1.5.0.40 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.37
[21:35:53.170][DJIFirmPackListRefre] 1.4.0.30 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.20
[21:35:53.170][DJIFirmPackListRefre] 1.3.0.20 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.08.95
[21:35:53.170][DJIFirmPackListRefre] 1.2.0.10 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.08.62
[21:35:53.170][DJIFirmPackListRefre] 1.1.0.0 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.08.28
[21:36:11.964][DJIUpgradeMgr ] ServiceUrl : https://mydjiflight.dji.com/links/links/hg700
[21:36:11.964][DJIUpgradeView ] userType :
[21:36:11.975][DJIDeviceInfoEnumera] 5% 1/17 GCU(7)
[21:36:11.975][DJIDeviceInfoEnumera] 11% 2/17 IMU(0)
[21:36:11.975][DJIDeviceInfoEnumera] 17% 3/17 Pitch(1)
[21:36:11.975][DJIDeviceInfoEnumera] 23% 4/17 Roll(2)
[21:36:11.975][DJIDeviceInfoEnumera] 29% 5/17 Battery(0)
[21:36:12.475][DJIDeviceInfoEnumera] 35% 6/17 Focus_Wheel(1)
[21:36:13.591][DJIDeviceInfoEnumera] 41% 7/17 Yaw(3)
[21:36:13.989][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Bluetooth(7:1)
[21:36:13.989][DJIDeviceInfoEnumera] 47% 8/17 Bluetooth(1)
[21:36:13.989][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD(5:6)
[21:36:13.989][DJIDeviceInfoEnumera] 52% 9/17 LCD(6)
[21:36:13.989][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD_flash(5:3)
[21:36:13.989][DJIDeviceInfoEnumera] 58% 10/17 LCD_flash(3)
[21:36:13.989][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: On-board Mount(5:0)
[21:36:13.989][DJIDeviceInfoEnumera] 64% 11/17 On-board Mount(0)
[21:36:13.999][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Handler(5:4)
[21:36:13.999][DJIDeviceInfoEnumera] 70% 12/17 Focus Handler(4)
[21:36:13.999][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: RC Handler(5:5)
[21:36:13.999][DJIDeviceInfoEnumera] 76% 13/17 RC Handler(5)
[21:36:13.999][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: EXT_GPS(5:1)
[21:36:13.999][DJIDeviceInfoEnumera] 82% 14/17 EXT_GPS(1)
[21:36:13.999][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Motor(31:5)
[21:36:13.999][DJIDeviceInfoEnumera] 88% 15/17 Focus Motor(5)
[21:36:13.999][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Iris Motor (31:6)
[21:36:13.999][DJIDeviceInfoEnumera] 94% 16/17 Iris Motor (6)
[21:36:14.009][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Zoom Motor(31:7)
[21:36:14.009][DJIDeviceInfoEnumera] 100% 17/17 Zoom Motor(7)
[21:36:14.009][DJIDeviceInfoEnumera] GCU (5 :7) Ldr : 01.00.03.00 App : 01.00.06.40
[21:36:14.009][DJIDeviceInfoEnumera] IMU (4 :0) Ldr : 09.01.00.17 App : 00.01.10.15 GB09
[21:36:14.009][DJIDeviceInfoEnumera] Pitch (4 :1) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:36:14.009][DJIDeviceInfoEnumera] Roll (4 :2) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:36:14.009][DJIDeviceInfoEnumera] Yaw (4 :3) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:36:14.009][DJIDeviceInfoEnumera] Bluetooth (7 :1) device no reply, request timeout!
[21:36:14.009][DJIDeviceInfoEnumera] Focus_Wheel (6 :1) Ldr : 01.00.00.00 App : 02.02.00.07
[21:36:14.009][DJIDeviceInfoEnumera] LCD (5 :6) device no reply, request timeout!
[21:36:14.009][DJIDeviceInfoEnumera] LCD_flash (5 :3) device no reply, request timeout!
[21:36:14.009][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[21:36:14.009][DJIDeviceInfoEnumera] Focus Handler (5 :4) device no reply, request timeout!
[21:36:14.009][DJIDeviceInfoEnumera] RC Handler (5 :5) device no reply, request timeout!
[21:36:14.010][DJIDeviceInfoEnumera] Battery (11:0) Ldr : 00.00.00.01 App : 04.73.05.07 HG700BATTERY
[21:36:14.010][DJIDeviceInfoEnumera] EXT_GPS (5 :1) device no reply, request timeout!
[21:36:14.010][DJIDeviceInfoEnumera] Focus Motor (31:5) device no reply, request timeout!
[21:36:14.010][DJIDeviceInfoEnumera] Iris Motor (31:6) device no reply, request timeout!
[21:36:14.010][DJIDeviceInfoEnumera] Zoom Motor (31:7) device no reply, request timeout!
[21:36:14.010][DJIServerApi ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700
[21:36:14.173][DJIWebFileGetter ] [OnFinish]reply statusCode=302
[21:36:14.240][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:36:14.268][DJIFirmPackListRefre] 1.9.0.80 Gimbal(0) higher, Cur: 00.01.10.15, Dst: 00.02.10.89
[21:36:14.268][DJIFirmPackListRefre] 1.9.0.80 Gimbal(1) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:36:14.269][DJIFirmPackListRefre] 1.9.0.80 Gimbal(2) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:36:14.269][DJIFirmPackListRefre] 1.9.0.80 Gimbal(3) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:36:14.269][DJIFirmPackListRefre] 1.9.0.80 Center_board(7) higher, Cur: 01.00.06.40, Dst: 01.00.06.59
[21:36:14.269][DJIFirmPackListRefre] 1.9.0.80 Remote_radio(1) equal , Cur: 02.02.00.07, Dst: 02.02.00.07
[21:36:14.269][DJIFirmPackListRefre] 1.9.0.80 Battery(0) equal , Cur: 04.73.05.07, Dst: 04.73.05.07
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Gimbal(0) equal , Cur: 00.01.10.15, Dst: 00.01.10.15
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Gimbal(1) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Gimbal(2) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Gimbal(3) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Center_board(7) equal , Cur: 01.00.06.40, Dst: 01.00.06.40
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Remote_radio(1) equal , Cur: 02.02.00.07, Dst: 02.02.00.07
[21:36:14.269][DJIFirmPackListRefre] 1.8.0.70 Battery(0) equal , Cur: 04.73.05.07, Dst: 04.73.05.07
[21:36:14.269][DJIFirmPackListRefre] 1.7.0.60 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.68
[21:36:14.269][DJIFirmPackListRefre] 1.6.0.50 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.66
[21:36:14.269][DJIFirmPackListRefre] 1.5.0.40 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.37
[21:36:14.270][DJIFirmPackListRefre] 1.4.0.30 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.09.20
[21:36:14.270][DJIFirmPackListRefre] 1.3.0.20 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.08.95
[21:36:14.270][DJIFirmPackListRefre] 1.2.0.10 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.08.62
[21:36:14.270][DJIFirmPackListRefre] 1.1.0.0 Gimbal(0) lower , Cur: 00.01.10.15, Dst: 00.01.08.28
[21:36:21.451][DJIWebFileGetter ] [OnFinish]reply statusCode=302
[21:36:24.559][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 1% 4.84 kB/s
[21:36:24.697][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 6% 29.32 kB/s
[21:36:24.797][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 12% 52.36 kB/s
[21:36:24.898][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 25% 101.88 kB/s
[21:36:25.232][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 32% 118.27 kB/s
[21:36:26.229][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 47% 137.13 kB/s
[21:36:26.374][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 62% 175.34 kB/s
[21:36:26.476][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 69% 190.88 kB/s
[21:36:26.941][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 74% 189.29 kB/s
[21:36:27.042][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 84% 208.76 kB/s
[21:36:27.440][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 87% 202.90 kB/s
[21:36:27.556][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 92% 209.53 kB/s
[21:36:27.650][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 100% 224.02 kB/s
[21:36:27.650][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:36:27.654][DJIFirmServiceAgent1] Center_board, 0 Size: 79004 Hash: ad4d3ada74e6440efb26e61b83701833 ENC: 0
[21:36:27.654][DJIFirmServiceAgent1] Gimbal, 1 Size: 188416 Hash: c676db0962c2f4b2dc97891fc8c09038 ENC: 0
[21:36:27.655][DJIFirmServiceAgent1] Gimbal, 0 Size: 396644 Hash: 14cb23394ac03806030670e5442e25ec ENC: 0
[21:36:27.655][DJIFirmServiceAgent1] Gimbal, 0 Size: 29196 Hash: a857e3fc7790d187885d285276337f3e ENC: 0
[21:36:27.655][DJIFirmServiceAgent1] Center_board, 0 Size: 320300 Hash: 5c9453879e7f35101ac7c8fd80b58d4c ENC: 0
[21:36:27.655][DJIFirmServiceAgent1] Remote_radio, 0 Size: 14440 Hash: 65f3eabb9fb6206a95ed0827f75caeb0 ENC: 0
[21:36:27.655][DJIFirmServiceAgent1] Any, 0 Size: 14440 Hash: 65f3eabb9fb6206a95ed0827f75caeb0 ENC: 0
[21:36:27.655][DJIFirmServiceAgent1] Wifi, 0 Size: 126976 Hash: 7f0eea52c45c45980918fe0a867a597e ENC: 0
[21:36:27.656][DJIFirmServiceAgent1] Last, 0 Size: 34460 Hash: f3c255b470e5eaede90a429ad725863e ENC: 0
[21:36:27.656][DJIFirmServiceAgent1] Battery, 0 Size: 90032 Hash: fe70fbd08adf6127225029566bec5457 ENC: 0
[21:36:27.658][DJIFirmUpgrader1 ] Skip file:Gimbal(0) 1 , version is same!
[21:36:27.661][DJIFirmUpgrader1 ] Skip file:Gimbal(1) 0 , version is same!
[21:36:27.661][DJIFirmUpgrader1 ] Skip file:Gimbal(2) 0 , version is same!
[21:36:27.661][DJIFirmUpgrader1 ] Skip file:Gimbal(3) 0 , version is same!
[21:36:27.661][DJIFirmUpgrader1 ] Skip file:Center_board(6) 0 , device is not connected!
[21:36:27.661][DJIFirmUpgrader1 ] Skip file:Remote_radio(1) 0 , version is same!
[21:36:27.661][DJIFirmUpgrader1 ] Skip file:Wifi(1) 0 , device is not connected!
[21:36:27.661][DJIFirmUpgrader1 ] Skip fileast(5) 0 , device is not connected!
[21:36:27.661][DJIFirmUpgrader1 ] Skip fileast(6) 0 , device is not connected!
[21:36:27.661][DJIFirmUpgrader1 ] Skip fileast(7) 0 , device is not connected!
[21:36:27.662][DJIFirmUpgrader1 ] Skip file:Battery(0) 0 , version is same!
[21:36:27.662][DJIFirmUpgrader1 ] Total [2] file need to upgrade:
[21:36:27.662][DJIFirmUpgrader1 ] Center_board(7) Size:79004 FirmType:App
[21:36:27.662][DJIFirmUpgrader1 ] Gimbal(0) Size:396644 FirmType:App
[21:36:27.662][DJIFirmUpgrader1 ] End file list!
[21:36:27.663][DJIFirmUpgrader1 ] device type: 5, device index: 7, data size: 79004
[21:36:27.694][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.03 second
[21:36:27.849][DJIFirmwareUpgrader ] Wait [ query_status] 0.16 second
[21:36:28.100][DJIFirmwareUpgrader ] Wait [ query_status] 0.41 second
[21:36:28.236][DJIIdentifierMgr ] Device Remove COM3
[21:36:28.236][DJISerialIo ] Free COM3 success!
[21:36:28.236][DJICmdIo ] DJICmdIo closed.
[21:36:28.236][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:36:28.348][DJIFirmwareUpgrader ] Wait [ query_status] 0.65 second
[21:36:28.598][DJIFirmwareUpgrader ] Wait [ query_status] 0.90 second
[21:36:28.849][DJIFirmwareUpgrader ] Wait [ query_status] 1.15 second
[21:36:29.099][DJIFirmwareUpgrader ] Wait [ query_status] 1.40 second
[21:36:29.349][DJIFirmwareUpgrader ] Wait [ query_status] 1.65 second
[21:36:29.453][DJIIdentifierMgr ] Device Arrive COM3
[21:36:29.453][DJICmdIo ] open COM3
[21:36:29.655][DJISerialIo ] Open COM3 success!
[21:36:29.655][DJIIdentifierMgr ] open device succeed
[21:36:29.655][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:36:29.655][gen_idf_COM3 ] Release DJIIdentifier.
[21:36:29.656][DJIFirmwareUpgrader ] Wait [ query_status] 1.96 second
[21:36:29.703][gen_idf_COM3 ] Center_board(7) quick resume in upgrading mode!!!
[21:36:29.703][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.40 ], Ldr
[21:36:29.703][DJIDeviceMgr ] device upgrading resume in loader! COM3
[21:36:29.703][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, activated
[21:36:29.825][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:36:29.848][DJIFirmwareUpgrader ] Wait [ query_status] 2.15 second
[21:36:30.099][DJIFirmwareUpgrader ] Wait [ query_status] 2.40 second
[21:36:30.349][DJIFirmwareUpgrader ] Wait [ query_status] 2.65 second
[21:36:30.599][DJIFirmwareUpgrader ] Wait [ query_status] 2.90 second
[21:36:30.849][DJIFirmwareUpgrader ] Wait [ query_status] 3.15 second
[21:36:31.099][DJIFirmwareUpgrader ] Wait [ query_status] 3.40 second
[21:36:31.228][DJIFirmwareUpgrader ] Wait [ query_status] 3.53 second
[21:36:31.349][DJIFirmwareUpgrader ] Wait [ prepare] 0.12 second
[21:36:31.598][DJIFirmwareUpgrader ] Wait [ prepare] 0.37 second
[21:36:31.849][DJIFirmwareUpgrader ] Wait [ prepare] 0.62 second
[21:36:32.099][DJIFirmwareUpgrader ] Wait [ prepare] 0.87 second
[21:36:32.349][DJIFirmwareUpgrader ] Wait [ prepare] 1.12 second
[21:36:32.598][DJIFirmwareUpgrader ] Wait [ prepare] 1.37 second
[21:36:32.849][DJIFirmwareUpgrader ] Wait [ prepare] 1.62 second
[21:36:33.098][DJIFirmwareUpgrader ] Wait [ prepare] 1.87 second
[21:36:33.348][DJIFirmwareUpgrader ] Wait [ prepare] 2.12 second
[21:36:33.594][DJIFirmwareUpgrader ] Wait [ prepare] 2.37 second
[21:36:37.349][DJIFirmwareUpgrader ] Wait [ verify] 0.04 second
[21:36:37.350][DJIFirmwareUpgrader ] Wait [ verify] 0.04 second
[21:36:37.356][DJIFirmwareUpgrader ] Wait [ reboot] 0.01 second
[21:36:37.634][DJIIdentifierMgr ] Device Remove COM3
[21:36:37.635][DJISerialIo ] Free COM3 success!
[21:36:37.635][DJICmdIo ] DJICmdIo closed.
[21:36:37.635][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:36:37.635][DJIFirmwareUpgrader ] Wait [ version] 0.28 second
[21:36:37.848][DJIFirmwareUpgrader ] Wait [ version] 0.49 second
[21:36:38.098][DJIFirmwareUpgrader ] Wait [ version] 0.74 second
[21:36:38.348][DJIFirmwareUpgrader ] Wait [ version] 0.99 second
[21:36:38.599][DJIFirmwareUpgrader ] Wait [ version] 1.24 second
[21:36:38.849][DJIFirmwareUpgrader ] Wait [ version] 1.49 second
[21:36:39.099][DJIFirmwareUpgrader ] Wait [ version] 1.74 second
[21:36:39.349][DJIFirmwareUpgrader ] Wait [ version] 1.99 second
[21:36:39.598][DJIFirmwareUpgrader ] Wait [ version] 2.24 second
[21:36:39.848][DJIFirmwareUpgrader ] Wait [ version] 2.49 second
[21:36:40.099][DJIFirmwareUpgrader ] Wait [ version] 2.74 second
[21:36:40.349][DJIFirmwareUpgrader ] Wait [ version] 2.99 second
[21:36:40.598][DJIFirmwareUpgrader ] Wait [ version] 3.24 second
[21:36:40.848][DJIFirmwareUpgrader ] Wait [ version] 3.49 second
[21:36:41.021][DJIIdentifierMgr ] Device Arrive COM3
[21:36:41.021][DJICmdIo ] open COM3
[21:36:41.221][DJISerialIo ] Open COM3 success!
[21:36:41.221][DJIIdentifierMgr ] open device succeed
[21:36:41.221][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:36:41.221][gen_idf_COM3 ] Release DJIIdentifier.
[21:36:41.222][DJIFirmwareUpgrader ] Wait [ version] 3.87 second
[21:36:41.296][gen_idf_COM3 ] GetModuleActivateStatus1 Error! ErrorId : 2
[21:36:41.307][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.59 ], App
[21:36:41.308][DJIDeviceMgr ] device service ready! COM3
[21:36:41.308][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, activated
[21:36:41.348][DJIFirmwareUpgrader ] Wait [ version] 3.99 second
[21:36:41.462][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:36:41.599][DJIFirmwareUpgrader ] Wait [ version] 4.24 second
[21:36:41.848][DJIFirmwareUpgrader ] Wait [ version] 4.49 second
[21:36:42.099][DJIFirmwareUpgrader ] Wait [ version] 4.74 second
[21:36:42.349][DJIFirmwareUpgrader ] Wait [ version] 4.99 second
[21:36:42.351][DJIFirmUpgrader1 ] Success upgrade to: 01.00.06.59(App)
[21:36:42.351][DJIFirmwareUpgrader ] Wait [ version] 4.99 second
[21:36:42.351][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[21:36:42.351][DJIFirmUpgrader1 ] device type: 4, device index: 0, data size: 396644
[21:36:42.352][DJIFirmUpgrader1 ] ======================= Time : 14.69 second
[21:36:42.429][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.08 second
[21:36:42.599][DJIFirmwareUpgrader ] Wait [ query_status] 0.17 second
[21:36:42.848][DJIFirmwareUpgrader ] Wait [ query_status] 0.42 second
[21:36:43.099][DJIFirmwareUpgrader ] Wait [ query_status] 0.67 second
[21:36:43.349][DJIFirmwareUpgrader ] Wait [ query_status] 0.92 second
[21:36:43.599][DJIFirmwareUpgrader ] Wait [ query_status] 1.17 second
[21:36:43.848][DJIFirmwareUpgrader ] Wait [ query_status] 1.42 second
[21:36:44.099][DJIFirmwareUpgrader ] Wait [ query_status] 1.67 second
[21:36:44.349][DJIFirmwareUpgrader ] Wait [ query_status] 1.92 second
[21:36:44.598][DJIFirmwareUpgrader ] Wait [ query_status] 2.17 second
[21:36:44.848][DJIFirmwareUpgrader ] Wait [ query_status] 2.42 second
[21:36:45.099][DJIFirmwareUpgrader ] Wait [ query_status] 2.67 second
[21:36:45.349][DJIFirmwareUpgrader ] Wait [ query_status] 2.92 second
[21:36:45.599][DJIFirmwareUpgrader ] Wait [ query_status] 3.17 second
[21:36:45.850][DJIFirmwareUpgrader ] Wait [ query_status] 3.42 second
[21:36:45.945][DJIFirmwareUpgrader ] Wait [ query_status] 3.52 second
[21:36:46.099][DJIFirmwareUpgrader ] Wait [ prepare] 0.15 second
[21:36:46.348][DJIFirmwareUpgrader ] Wait [ prepare] 0.40 second
[21:36:46.599][DJIFirmwareUpgrader ] Wait [ prepare] 0.65 second
[21:36:46.849][DJIFirmwareUpgrader ] Wait [ prepare] 0.90 second
[21:36:47.099][DJIFirmwareUpgrader ] Wait [ prepare] 1.15 second
[21:36:47.350][DJIFirmwareUpgrader ] Wait [ prepare] 1.40 second
[21:36:47.599][DJIFirmwareUpgrader ] Wait [ prepare] 1.65 second
[21:36:47.848][DJIFirmwareUpgrader ] Wait [ prepare] 1.90 second
[21:36:47.991][DJIFirmwareUpgrader ] Wait [ prepare] 2.05 second
[21:39:41.944][DJIFirmwareUpgrader ] Wait [ verify] 0.06 second
[21:39:42.098][DJIFirmwareUpgrader ] Wait [ reboot] 0.15 second
[21:39:42.349][DJIFirmwareUpgrader ] Wait [ reboot] 0.41 second
[21:39:42.599][DJIFirmwareUpgrader ] Wait [ reboot] 0.65 second
[21:39:42.848][DJIFirmwareUpgrader ] Wait [ reboot] 0.90 second
[21:39:42.957][DJIFirmwareUpgrader ] Wait [ reboot] 1.01 second
[21:39:43.100][DJIFirmwareUpgrader ] Wait [ version] 0.14 second
[21:39:43.349][DJIFirmwareUpgrader ] Wait [ version] 0.39 second
[21:39:43.598][DJIFirmwareUpgrader ] Wait [ version] 0.64 second
[21:39:43.850][DJIFirmwareUpgrader ] Wait [ version] 0.89 second
[21:39:44.098][DJIFirmwareUpgrader ] Wait [ version] 1.14 second
[21:39:44.349][DJIFirmwareUpgrader ] Wait [ version] 1.39 second
[21:39:44.599][DJIFirmwareUpgrader ] Wait [ version] 1.64 second
[21:39:44.848][DJIFirmwareUpgrader ] Wait [ version] 1.89 second
[21:39:45.099][DJIFirmwareUpgrader ] Wait [ version] 2.14 second
[21:39:45.349][DJIFirmwareUpgrader ] Wait [ version] 2.39 second
[21:39:45.599][DJIFirmwareUpgrader ] Wait [ version] 2.64 second
[21:39:45.848][DJIFirmwareUpgrader ] Wait [ version] 2.89 second
[21:39:46.099][DJIFirmwareUpgrader ] Wait [ version] 3.14 second
[21:39:46.349][DJIFirmwareUpgrader ] Wait [ version] 3.39 second
[21:39:46.599][DJIFirmwareUpgrader ] Wait [ version] 3.64 second
[21:39:46.850][DJIFirmwareUpgrader ] Wait [ version] 3.89 second
[21:39:47.099][DJIFirmwareUpgrader ] Wait [ version] 4.14 second
[21:39:47.349][DJIFirmwareUpgrader ] Wait [ version] 4.39 second
[21:39:47.600][DJIFirmwareUpgrader ] Wait [ version] 4.64 second
[21:39:47.849][DJIFirmwareUpgrader ] Wait [ version] 4.89 second
[21:39:47.950][DJIFirmUpgrader1 ] Success upgrade to: 00.02.10.89(App)
[21:39:47.950][DJIFirmwareUpgrader ] Wait [ version] 4.99 second
[21:39:47.950][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[21:39:47.950][DJIFirmUpgrader1 ] device Wifi(1) is not connected!
[21:39:47.950][DJIFirmUpgrader1 ] ======================= Time : 185.60 second
[21:40:30.144][DJIDeviceInfoEnumera] 5% 1/17 GCU(7)
[21:40:30.144][DJIDeviceInfoEnumera] 11% 2/17 Battery(0)
[21:40:30.149][DJIDeviceInfoEnumera] 17% 3/17 Roll(2)
[21:40:30.150][DJIDeviceInfoEnumera] 23% 4/17 Yaw(3)
[21:40:30.647][DJIDeviceInfoEnumera] 29% 5/17 Focus_Wheel(1)
[21:40:30.948][DJIDeviceInfoEnumera] 35% 6/17 IMU(0)
[21:40:30.954][DJIDeviceInfoEnumera] 41% 7/17 Pitch(1)
[21:40:32.169][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Bluetooth(7:1)
[21:40:32.169][DJIDeviceInfoEnumera] 47% 8/17 Bluetooth(1)
[21:40:32.169][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD(5:6)
[21:40:32.169][DJIDeviceInfoEnumera] 52% 9/17 LCD(6)
[21:40:32.169][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD_flash(5:3)
[21:40:32.169][DJIDeviceInfoEnumera] 58% 10/17 LCD_flash(3)
[21:40:32.169][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: On-board Mount(5:0)
[21:40:32.169][DJIDeviceInfoEnumera] 64% 11/17 On-board Mount(0)
[21:40:32.179][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Handler(5:4)
[21:40:32.179][DJIDeviceInfoEnumera] 70% 12/17 Focus Handler(4)
[21:40:32.179][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: RC Handler(5:5)
[21:40:32.179][DJIDeviceInfoEnumera] 76% 13/17 RC Handler(5)
[21:40:32.179][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: EXT_GPS(5:1)
[21:40:32.179][DJIDeviceInfoEnumera] 82% 14/17 EXT_GPS(1)
[21:40:32.179][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Motor(31:5)
[21:40:32.179][DJIDeviceInfoEnumera] 88% 15/17 Focus Motor(5)
[21:40:32.179][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Iris Motor (31:6)
[21:40:32.179][DJIDeviceInfoEnumera] 94% 16/17 Iris Motor (6)
[21:40:32.189][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Zoom Motor(31:7)
[21:40:32.189][DJIDeviceInfoEnumera] 100% 17/17 Zoom Motor(7)
[21:40:32.189][DJIDeviceInfoEnumera] GCU (5 :7) Ldr : 01.00.03.00 App : 01.00.06.59
[21:40:32.189][DJIDeviceInfoEnumera] IMU (4 :0) Ldr : 09.01.00.17 App : 00.02.10.89 GB09
[21:40:32.189][DJIDeviceInfoEnumera] Pitch (4 :1) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:40:32.189][DJIDeviceInfoEnumera] Roll (4 :2) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:40:32.189][DJIDeviceInfoEnumera] Yaw (4 :3) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:40:32.189][DJIDeviceInfoEnumera] Bluetooth (7 :1) device no reply, request timeout!
[21:40:32.189][DJIDeviceInfoEnumera] Focus_Wheel (6 :1) Ldr : 01.00.00.00 App : 02.02.00.07
[21:40:32.189][DJIDeviceInfoEnumera] LCD (5 :6) device no reply, request timeout!
[21:40:32.189][DJIDeviceInfoEnumera] LCD_flash (5 :3) device no reply, request timeout!
[21:40:32.189][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[21:40:32.189][DJIDeviceInfoEnumera] Focus Handler (5 :4) device no reply, request timeout!
[21:40:32.189][DJIDeviceInfoEnumera] RC Handler (5 :5) device no reply, request timeout!
[21:40:32.189][DJIDeviceInfoEnumera] Battery (11:0) Ldr : 00.00.00.01 App : 04.73.05.07 HG700BATTERY
[21:40:32.189][DJIDeviceInfoEnumera] EXT_GPS (5 :1) device no reply, request timeout!
[21:40:32.190][DJIDeviceInfoEnumera] Focus Motor (31:5) device no reply, request timeout!
[21:40:32.190][DJIDeviceInfoEnumera] Iris Motor (31:6) device no reply, request timeout!
[21:40:32.190][DJIDeviceInfoEnumera] Zoom Motor (31:7) device no reply, request timeout!
[21:40:32.190][DJIServerApi ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700
[21:40:32.472][DJIWebFileGetter ] [OnFinish]reply statusCode=302
[21:40:32.992][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Gimbal(0) equal , Cur: 00.02.10.89, Dst: 00.02.10.89
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Gimbal(1) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Gimbal(2) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Gimbal(3) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Center_board(7) equal , Cur: 01.00.06.59, Dst: 01.00.06.59
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Remote_radio(1) equal , Cur: 02.02.00.07, Dst: 02.02.00.07
[21:40:33.020][DJIFirmPackListRefre] 1.9.0.80 Battery(0) equal , Cur: 04.73.05.07, Dst: 04.73.05.07
[21:40:33.021][DJIFirmPackListRefre] 1.8.0.70 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.10.15
[21:40:33.021][DJIFirmPackListRefre] 1.7.0.60 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.68
[21:40:33.021][DJIFirmPackListRefre] 1.6.0.50 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.66
[21:40:33.021][DJIFirmPackListRefre] 1.5.0.40 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.37
[21:40:33.021][DJIFirmPackListRefre] 1.4.0.30 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.20
[21:40:33.021][DJIFirmPackListRefre] 1.3.0.20 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.08.95
[21:40:33.021][DJIFirmPackListRefre] 1.2.0.10 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.08.62
[21:40:33.021][DJIFirmPackListRefre] 1.1.0.0 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.08.28
[21:40:33.808][DJIWebFileGetter ] [OnFinish]reply statusCode=302
[21:40:33.935][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 1% 130.82 kB/s
[21:40:34.093][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 3% 170.58 kB/s
[21:40:34.414][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 5% 135.35 kB/s
[21:40:34.659][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 8% 133.82 kB/s
[21:40:35.007][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 10% 121.67 kB/s
[21:40:35.195][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 12% 121.26 kB/s
[21:40:35.296][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 14% 134.45 kB/s
[21:40:35.451][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 15% 131.51 kB/s
[21:40:35.759][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 19% 135.35 kB/s
[21:40:35.973][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 20% 129.36 kB/s
[21:40:36.085][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 23% 144.08 kB/s
[21:40:36.262][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 25% 146.73 kB/s
[21:40:36.499][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 32% 169.48 kB/s
[21:40:36.606][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 35% 174.43 kB/s
[21:40:36.766][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 36% 170.41 kB/s
[21:40:36.906][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 38% 173.04 kB/s
[21:40:37.074][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 39% 169.03 kB/s
[21:40:37.297][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 40% 162.82 kB/s
[21:40:37.416][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 44% 170.75 kB/s
[21:40:37.582][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 45% 167.48 kB/s
[21:40:37.838][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 48% 168.75 kB/s
[21:40:38.099][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 52% 169.67 kB/s
[21:40:38.237][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 54% 171.61 kB/s
[21:40:38.370][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 55% 170.11 kB/s
[21:40:38.478][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 58% 173.03 kB/s
[21:40:38.650][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 59% 170.19 kB/s
[21:40:38.901][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 62% 171.23 kB/s
[21:40:39.022][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 68% 182.60 kB/s
[21:40:39.171][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 69% 180.51 kB/s
[21:40:39.313][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 73% 184.57 kB/s
[21:40:39.446][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 75% 185.89 kB/s
[21:40:39.776][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 81% 189.02 kB/s
[21:40:39.974][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 85% 193.33 kB/s
[21:40:40.101][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 88% 194.51 kB/s
[21:40:40.344][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 90% 192.18 kB/s
[21:40:40.460][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 93% 196.04 kB/s
[21:40:40.568][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 96% 197.64 kB/s
[21:40:40.830][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 98% 194.83 kB/s
[21:40:40.891][DJIWebFileGetter ] Downloading [HG700_FW_V01.09.00.80.bin] 100% 196.06 kB/s
[21:40:40.891][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:40:40.895][DJIFirmServiceAgent1] Center_board, 0 Size: 79004 Hash: ad4d3ada74e6440efb26e61b83701833 ENC: 0
[21:40:40.895][DJIFirmServiceAgent1] Gimbal, 1 Size: 188416 Hash: c676db0962c2f4b2dc97891fc8c09038 ENC: 0
[21:40:40.895][DJIFirmServiceAgent1] Gimbal, 0 Size: 396644 Hash: 14cb23394ac03806030670e5442e25ec ENC: 0
[21:40:40.895][DJIFirmServiceAgent1] Gimbal, 0 Size: 29196 Hash: a857e3fc7790d187885d285276337f3e ENC: 0
[21:40:40.896][DJIFirmServiceAgent1] Center_board, 0 Size: 320300 Hash: 5c9453879e7f35101ac7c8fd80b58d4c ENC: 0
[21:40:40.896][DJIFirmServiceAgent1] Remote_radio, 0 Size: 14440 Hash: 65f3eabb9fb6206a95ed0827f75caeb0 ENC: 0
[21:40:40.896][DJIFirmServiceAgent1] Any, 0 Size: 14440 Hash: 65f3eabb9fb6206a95ed0827f75caeb0 ENC: 0
[21:40:40.896][DJIFirmServiceAgent1] Wifi, 0 Size: 126976 Hash: 7f0eea52c45c45980918fe0a867a597e ENC: 0
[21:40:40.896][DJIFirmServiceAgent1] Last, 0 Size: 34460 Hash: f3c255b470e5eaede90a429ad725863e ENC: 0
[21:40:40.896][DJIFirmServiceAgent1] Battery, 0 Size: 90032 Hash: fe70fbd08adf6127225029566bec5457 ENC: 0
[21:40:40.897][DJIFirmUpgrader1 ] Skip file:Center_board(7) 0 , version is same!
[21:40:40.898][DJIFirmUpgrader1 ] Skip file:Gimbal(0) 1 , version is same!
[21:40:40.901][DJIFirmUpgrader1 ] Skip file:Gimbal(0) 0 , version is same!
[21:40:40.901][DJIFirmUpgrader1 ] Skip file:Gimbal(1) 0 , version is same!
[21:40:40.901][DJIFirmUpgrader1 ] Skip file:Gimbal(2) 0 , version is same!
[21:40:40.902][DJIFirmUpgrader1 ] Skip file:Gimbal(3) 0 , version is same!
[21:40:40.902][DJIFirmUpgrader1 ] Skip file:Center_board(6) 0 , device is not connected!
[21:40:40.902][DJIFirmUpgrader1 ] Skip file:Remote_radio(1) 0 , version is same!
[21:40:40.902][DJIFirmUpgrader1 ] Skip file:Wifi(1) 0 , device is not connected!
[21:40:40.902][DJIFirmUpgrader1 ] Skip fileast(5) 0 , device is not connected!
[21:40:40.902][DJIFirmUpgrader1 ] Skip fileast(6) 0 , device is not connected!
[21:40:40.902][DJIFirmUpgrader1 ] Skip fileast(7) 0 , device is not connected!
[21:40:40.903][DJIFirmUpgrader1 ] Skip file:Battery(0) 0 , version is same!
[21:40:40.903][DJIFirmUpgrader1 ] Total [0] file need to upgrade:
[21:40:40.903][DJIFirmUpgrader1 ] End file list!
[21:40:40.903][DJIFirmUpgrader1 ] device Wifi(1) is not connected!
[21:42:22.039][DJIIdentifierMgr ] Device Remove COM3
[21:42:22.039][DJISerialIo ] Free COM3 success!
[21:42:22.039][DJICmdIo ] DJICmdIo closed.
[21:42:22.039][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:42:39.468][DJIIdentifierMgr ] Device Arrive COM3
[21:42:39.468][DJICmdIo ] open COM3
[21:42:39.669][DJISerialIo ] Open COM3 success!
[21:42:39.669][DJIIdentifierMgr ] open device succeed
[21:42:39.669][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:42:39.669][gen_idf_COM3 ] Release DJIIdentifier.
[21:42:39.730][gen_idf_COM3 ] GetModuleActivateStatus1 Error! ErrorId : 2
[21:42:39.742][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.59 ], App
[21:42:39.742][DJIDeviceMgr ] device service ready! COM3
[21:42:39.742][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:42:40.292][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:34.850][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:45:35.377][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:45:36.108][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:36.229][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:38.226][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:45:38.254][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:45:38.287][DJIUpgradeMgr ] ServiceUrl : https://mydjiflight.dji.com/links/links/hg700
[21:45:38.287][DJIUpgradeView ] userType :
[21:45:38.303][DJIDeviceInfoEnumera] 5% 1/17 GCU(7)
[21:45:38.303][DJIDeviceInfoEnumera] 11% 2/17 Battery(0)
[21:45:38.303][DJIDeviceInfoEnumera] 17% 3/17 Yaw(3)
[21:45:38.349][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:38.363][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:38.372][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:38.375][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:38.799][DJIDeviceInfoEnumera] 23% 4/17 Focus_Wheel(1)
[21:45:39.099][DJIDeviceInfoEnumera] 29% 5/17 IMU(0)
[21:45:39.100][DJIDeviceInfoEnumera] 35% 6/17 Pitch(1)
[21:45:39.914][DJIDeviceInfoEnumera] 41% 7/17 Roll(2)
[21:45:40.310][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Bluetooth(7:1)
[21:45:40.310][DJIDeviceInfoEnumera] 47% 8/17 Bluetooth(1)
[21:45:40.310][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD(5:6)
[21:45:40.310][DJIDeviceInfoEnumera] 52% 9/17 LCD(6)
[21:45:40.310][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD_flash(5:3)
[21:45:40.310][DJIDeviceInfoEnumera] 58% 10/17 LCD_flash(3)
[21:45:40.310][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: On-board Mount(5:0)
[21:45:40.310][DJIDeviceInfoEnumera] 64% 11/17 On-board Mount(0)
[21:45:40.320][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Handler(5:4)
[21:45:40.320][DJIDeviceInfoEnumera] 70% 12/17 Focus Handler(4)
[21:45:40.320][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: RC Handler(5:5)
[21:45:40.320][DJIDeviceInfoEnumera] 76% 13/17 RC Handler(5)
[21:45:40.320][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: EXT_GPS(5:1)
[21:45:40.320][DJIDeviceInfoEnumera] 82% 14/17 EXT_GPS(1)
[21:45:40.320][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Motor(31:5)
[21:45:40.320][DJIDeviceInfoEnumera] 88% 15/17 Focus Motor(5)
[21:45:40.320][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Iris Motor (31:6)
[21:45:40.320][DJIDeviceInfoEnumera] 94% 16/17 Iris Motor (6)
[21:45:40.330][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Zoom Motor(31:7)
[21:45:40.330][DJIDeviceInfoEnumera] 100% 17/17 Zoom Motor(7)
[21:45:40.330][DJIDeviceInfoEnumera] GCU (5 :7) Ldr : 01.00.03.00 App : 01.00.06.59
[21:45:40.330][DJIDeviceInfoEnumera] IMU (4 :0) Ldr : 09.01.00.17 App : 00.02.10.89 GB09
[21:45:40.330][DJIDeviceInfoEnumera] Pitch (4 :1) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:45:40.330][DJIDeviceInfoEnumera] Roll (4 :2) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:45:40.330][DJIDeviceInfoEnumera] Yaw (4 :3) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[21:45:40.330][DJIDeviceInfoEnumera] Bluetooth (7 :1) device no reply, request timeout!
[21:45:40.330][DJIDeviceInfoEnumera] Focus_Wheel (6 :1) Ldr : 01.00.00.00 App : 02.02.00.07
[21:45:40.330][DJIDeviceInfoEnumera] LCD (5 :6) device no reply, request timeout!
[21:45:40.330][DJIDeviceInfoEnumera] LCD_flash (5 :3) device no reply, request timeout!
[21:45:40.330][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[21:45:40.330][DJIDeviceInfoEnumera] Focus Handler (5 :4) device no reply, request timeout!
[21:45:40.330][DJIDeviceInfoEnumera] RC Handler (5 :5) device no reply, request timeout!
[21:45:40.331][DJIDeviceInfoEnumera] Battery (11:0) Ldr : 00.00.00.01 App : 04.73.05.07 HG700BATTERY
[21:45:40.331][DJIDeviceInfoEnumera] EXT_GPS (5 :1) device no reply, request timeout!
[21:45:40.331][DJIDeviceInfoEnumera] Focus Motor (31:5) device no reply, request timeout!
[21:45:40.331][DJIDeviceInfoEnumera] Iris Motor (31:6) device no reply, request timeout!
[21:45:40.331][DJIDeviceInfoEnumera] Zoom Motor (31:7) device no reply, request timeout!
[21:45:40.331][DJIServerApi ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700
[21:45:41.363][DJIWebFileGetter ] [OnFinish]reply statusCode=302
[21:45:41.586][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Gimbal(0) equal , Cur: 00.02.10.89, Dst: 00.02.10.89
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Gimbal(1) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Gimbal(2) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Gimbal(3) equal , Cur: 01.00.00.10, Dst: 01.00.00.10
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Center_board(7) equal , Cur: 01.00.06.59, Dst: 01.00.06.59
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Remote_radio(1) equal , Cur: 02.02.00.07, Dst: 02.02.00.07
[21:45:41.614][DJIFirmPackListRefre] 1.9.0.80 Battery(0) equal , Cur: 04.73.05.07, Dst: 04.73.05.07
[21:45:41.614][DJIFirmPackListRefre] 1.8.0.70 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.10.15
[21:45:41.615][DJIFirmPackListRefre] 1.7.0.60 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.68
[21:45:41.615][DJIFirmPackListRefre] 1.6.0.50 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.66
[21:45:41.615][DJIFirmPackListRefre] 1.5.0.40 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.37
[21:45:41.615][DJIFirmPackListRefre] 1.4.0.30 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.09.20
[21:45:41.615][DJIFirmPackListRefre] 1.3.0.20 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.08.95
[21:45:41.615][DJIFirmPackListRefre] 1.2.0.10 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.08.62
[21:45:41.615][DJIFirmPackListRefre] 1.1.0.0 Gimbal(0) lower , Cur: 00.02.10.89, Dst: 00.01.08.28
[21:45:53.293][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 2% 47.84 kB/s
[21:45:53.420][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 7% 122.45 kB/s
[21:45:53.624][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 19% 260.77 kB/s
[21:45:53.740][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 28% 331.54 kB/s
[21:45:53.879][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 40% 429.38 kB/s
[21:45:54.005][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 54% 518.58 kB/s
[21:45:54.201][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 57% 486.99 kB/s
[21:45:54.304][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 75% 594.30 kB/s
[21:45:54.477][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 76% 548.30 kB/s
[21:45:54.584][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 86% 591.39 kB/s
[21:45:54.790][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 90% 557.56 kB/s
[21:45:54.895][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 97% 573.81 kB/s
[21:45:55.045][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 100% 553.02 kB/s
[21:45:55.045][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 100% 552.79 kB/s
[21:45:55.045][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:55.046][DJIFirmServiceAgent1] Center_board, 0 Size: 77484 Hash: 6d3f8db23ec0235cde99734da205751a ENC: 0
[21:45:55.046][DJIFirmServiceAgent1] Gimbal, 1 Size: 188416 Hash: c676db0962c2f4b2dc97891fc8c09038 ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Gimbal, 0 Size: 380376 Hash: 35a67e74bb28cf0f4b011579cd969a50 ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Gimbal, 0 Size: 29196 Hash: a857e3fc7790d187885d285276337f3e ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Wifi, 0 Size: 126976 Hash: 68142a33c148e5101d85b446911d34d2 ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Remote_radio, 0 Size: 14376 Hash: 987838099390509d7e7f26d6b973940c ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Center_board, 0 Size: 320300 Hash: 5c9453879e7f35101ac7c8fd80b58d4c ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Last, 0 Size: 34460 Hash: f3c255b470e5eaede90a429ad725863e ENC: 0
[21:45:55.047][DJIFirmServiceAgent1] Battery, 0 Size: 90032 Hash: fe70fbd08adf6127225029566bec5457 ENC: 0
[21:45:55.048][DJIFirmUpgrader1 ] Skip file:Gimbal(0) 1 , version is same!
[21:45:55.048][DJIFirmUpgrader1 ] Skip file:Gimbal(1) 0 , version is same!
[21:45:55.048][DJIFirmUpgrader1 ] Skip file:Gimbal(2) 0 , version is same!
[21:45:55.048][DJIFirmUpgrader1 ] Skip file:Gimbal(3) 0 , version is same!
[21:45:55.049][DJIFirmUpgrader1 ] Skip file:Wifi(1) 0 , device is not connected!
[21:45:55.049][DJIFirmUpgrader1 ] Skip file:Center_board(6) 0 , device is not connected!
[21:45:55.049][DJIFirmUpgrader1 ] Skip fileast(5) 0 , device is not connected!
[21:45:55.049][DJIFirmUpgrader1 ] Skip fileast(6) 0 , device is not connected!
[21:45:55.049][DJIFirmUpgrader1 ] Skip fileast(7) 0 , device is not connected!
[21:45:55.049][DJIFirmUpgrader1 ] Skip file:Battery(0) 0 , version is same!
[21:45:55.049][DJIFirmUpgrader1 ] Total [3] file need to upgrade:
[21:45:55.049][DJIFirmUpgrader1 ] Center_board(7) Size:77484 FirmType:App
[21:45:55.049][DJIFirmUpgrader1 ] Gimbal(0) Size:380376 FirmType:App
[21:45:55.049][DJIFirmUpgrader1 ] Remote_radio(1) Size:14376 FirmType:App
[21:45:55.049][DJIFirmUpgrader1 ] End file list!
[21:45:55.049][DJIFirmUpgrader1 ] device type: 5, device index: 7, data size: 77484
[21:45:55.078][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.03 second
[21:45:55.098][DJIFirmwareUpgrader ] Wait [ query_status] 0.02 second
[21:45:55.348][DJIFirmwareUpgrader ] Wait [ query_status] 0.27 second
[21:45:55.588][DJIIdentifierMgr ] Device Remove COM3
[21:45:55.588][DJISerialIo ] Free COM3 success!
[21:45:55.588][DJICmdIo ] DJICmdIo closed.
[21:45:55.588][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:45:55.618][DJIFirmwareUpgrader ] Wait [ query_status] 0.54 second
[21:45:55.848][DJIFirmwareUpgrader ] Wait [ query_status] 0.77 second
[21:45:56.098][DJIFirmwareUpgrader ] Wait [ query_status] 1.02 second
[21:45:56.348][DJIFirmwareUpgrader ] Wait [ query_status] 1.27 second
[21:45:56.598][DJIFirmwareUpgrader ] Wait [ query_status] 1.52 second
[21:45:56.826][DJIIdentifierMgr ] Device Arrive COM3
[21:45:56.826][DJICmdIo ] open COM3
[21:45:57.027][DJISerialIo ] Open COM3 success!
[21:45:57.027][DJIIdentifierMgr ] open device succeed
[21:45:57.027][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:45:57.027][gen_idf_COM3 ] Release DJIIdentifier.
[21:45:57.028][DJIFirmwareUpgrader ] Wait [ query_status] 1.95 second
[21:45:57.034][gen_idf_COM3 ] Center_board(7) quick resume in upgrading mode!!!
[21:45:57.034][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.59 ], Ldr
[21:45:57.034][DJIDeviceMgr ] device upgrading resume in loader! COM3
[21:45:57.034][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:45:57.098][DJIFirmwareUpgrader ] Wait [ query_status] 2.02 second
[21:45:57.198][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:45:57.349][DJIFirmwareUpgrader ] Wait [ query_status] 2.27 second
[21:45:57.598][DJIFirmwareUpgrader ] Wait [ query_status] 2.52 second
[21:45:57.848][DJIFirmwareUpgrader ] Wait [ query_status] 2.77 second
[21:45:58.098][DJIFirmwareUpgrader ] Wait [ query_status] 3.02 second
[21:45:58.348][DJIFirmwareUpgrader ] Wait [ query_status] 3.27 second
[21:45:58.588][DJIFirmwareUpgrader ] Wait [ query_status] 3.51 second
[21:45:58.599][DJIFirmwareUpgrader ] Wait [ prepare] 0.01 second
[21:45:58.849][DJIFirmwareUpgrader ] Wait [ prepare] 0.26 second
[21:45:59.099][DJIFirmwareUpgrader ] Wait [ prepare] 0.51 second
[21:45:59.349][DJIFirmwareUpgrader ] Wait [ prepare] 0.76 second
[21:45:59.599][DJIFirmwareUpgrader ] Wait [ prepare] 1.01 second
[21:45:59.849][DJIFirmwareUpgrader ] Wait [ prepare] 1.26 second
[21:46:00.098][DJIFirmwareUpgrader ] Wait [ prepare] 1.51 second
[21:46:00.349][DJIFirmwareUpgrader ] Wait [ prepare] 1.76 second
[21:46:00.598][DJIFirmwareUpgrader ] Wait [ prepare] 2.01 second
[21:46:00.849][DJIFirmwareUpgrader ] Wait [ prepare] 2.26 second
[21:46:00.958][DJIFirmwareUpgrader ] Wait [ prepare] 2.37 second
[21:46:04.642][DJIFirmwareUpgrader ] Wait [ verify] 0.04 second
[21:46:04.648][DJIFirmwareUpgrader ] Wait [ reboot] 0.00 second
[21:46:04.849][DJIFirmwareUpgrader ] Wait [ version] 0.20 second
[21:46:04.923][DJIIdentifierMgr ] Device Remove COM3
[21:46:04.923][DJISerialIo ] Free COM3 success!
[21:46:04.923][DJICmdIo ] DJICmdIo closed.
[21:46:04.923][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.59, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:46:05.099][DJIFirmwareUpgrader ] Wait [ version] 0.45 second
[21:46:05.349][DJIFirmwareUpgrader ] Wait [ version] 0.70 second
[21:46:05.599][DJIFirmwareUpgrader ] Wait [ version] 0.95 second
[21:46:05.849][DJIFirmwareUpgrader ] Wait [ version] 1.20 second
[21:46:06.099][DJIFirmwareUpgrader ] Wait [ version] 1.45 second
[21:46:06.348][DJIFirmwareUpgrader ] Wait [ version] 1.70 second
[21:46:06.598][DJIFirmwareUpgrader ] Wait [ version] 1.95 second
[21:46:06.849][DJIFirmwareUpgrader ] Wait [ version] 2.20 second
[21:46:07.099][DJIFirmwareUpgrader ] Wait [ version] 2.45 second
[21:46:07.349][DJIFirmwareUpgrader ] Wait [ version] 2.70 second
[21:46:07.598][DJIFirmwareUpgrader ] Wait [ version] 2.95 second
[21:46:07.849][DJIFirmwareUpgrader ] Wait [ version] 3.20 second
[21:46:08.098][DJIFirmwareUpgrader ] Wait [ version] 3.45 second
[21:46:08.386][DJIIdentifierMgr ] Device Arrive COM3
[21:46:08.386][DJICmdIo ] open COM3
[21:46:08.588][DJISerialIo ] Open COM3 success!
[21:46:08.588][DJIIdentifierMgr ] open device succeed
[21:46:08.588][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:46:08.588][gen_idf_COM3 ] Release DJIIdentifier.
[21:46:08.589][DJIFirmwareUpgrader ] Wait [ version] 3.94 second
[21:46:08.636][DJIFirmwareUpgrader ] Wait [ version] 3.99 second
[21:46:08.669][gen_idf_COM3 ] GetModuleActivateStatus1 Error! ErrorId : 2
[21:46:08.681][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.40 ], App
[21:46:08.681][DJIDeviceMgr ] device service ready! COM3
[21:46:08.681][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:46:08.848][DJIFirmwareUpgrader ] Wait [ version] 4.20 second
[21:46:08.897][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:46:09.099][DJIFirmwareUpgrader ] Wait [ version] 4.45 second
[21:46:09.349][DJIFirmwareUpgrader ] Wait [ version] 4.70 second
[21:46:09.599][DJIFirmwareUpgrader ] Wait [ version] 4.95 second
[21:46:09.653][DJIFirmUpgrader1 ] Success upgrade to: 01.00.06.40(App)
[21:46:09.653][DJIFirmwareUpgrader ] Wait [ version] 5.00 second
[21:46:09.653][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[21:46:09.653][DJIFirmUpgrader1 ] device type: 4, device index: 0, data size: 380376
[21:46:09.653][DJIFirmUpgrader1 ] ======================= Time : 14.60 second
[21:46:09.731][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.08 second
[21:46:09.848][DJIFirmwareUpgrader ] Wait [ query_status] 0.12 second
[21:46:10.098][DJIFirmwareUpgrader ] Wait [ query_status] 0.37 second
[21:46:10.349][DJIFirmwareUpgrader ] Wait [ query_status] 0.62 second
[21:46:10.600][DJIFirmwareUpgrader ] Wait [ query_status] 0.87 second
[21:46:10.848][DJIFirmwareUpgrader ] Wait [ query_status] 1.12 second
[21:46:11.099][DJIFirmwareUpgrader ] Wait [ query_status] 1.37 second
[21:46:11.349][DJIFirmwareUpgrader ] Wait [ query_status] 1.62 second
[21:46:11.598][DJIFirmwareUpgrader ] Wait [ query_status] 1.87 second
[21:46:11.848][DJIFirmwareUpgrader ] Wait [ query_status] 2.12 second
[21:46:12.098][DJIFirmwareUpgrader ] Wait [ query_status] 2.37 second
[21:46:12.349][DJIFirmwareUpgrader ] Wait [ query_status] 2.62 second
[21:46:12.598][DJIFirmwareUpgrader ] Wait [ query_status] 2.87 second
[21:46:12.848][DJIFirmwareUpgrader ] Wait [ query_status] 3.12 second
[21:46:13.098][DJIFirmwareUpgrader ] Wait [ query_status] 3.37 second
[21:46:13.247][DJIFirmwareUpgrader ] Wait [ query_status] 3.52 second
[21:46:13.349][DJIFirmwareUpgrader ] Wait [ prepare] 0.10 second
[21:46:13.599][DJIFirmwareUpgrader ] Wait [ prepare] 0.35 second
[21:46:13.849][DJIFirmwareUpgrader ] Wait [ prepare] 0.60 second
[21:46:14.098][DJIFirmwareUpgrader ] Wait [ prepare] 0.85 second
[21:46:14.348][DJIFirmwareUpgrader ] Wait [ prepare] 1.10 second
[21:46:14.599][DJIFirmwareUpgrader ] Wait [ prepare] 1.35 second
[21:46:14.849][DJIFirmwareUpgrader ] Wait [ prepare] 1.60 second
[21:46:15.098][DJIFirmwareUpgrader ] Wait [ prepare] 1.85 second
[21:46:15.281][DJIFirmwareUpgrader ] Wait [ prepare] 2.03 second
[21:51:04.715][DJIFirmwareUpgrader ] Wait [ verify] 0.06 second
[21:51:04.849][DJIFirmwareUpgrader ] Wait [ reboot] 0.13 second
[21:51:05.099][DJIFirmwareUpgrader ] Wait [ reboot] 0.38 second
[21:51:05.349][DJIFirmwareUpgrader ] Wait [ reboot] 0.63 second
[21:51:05.599][DJIFirmwareUpgrader ] Wait [ reboot] 0.88 second
[21:51:05.723][DJIFirmwareUpgrader ] Wait [ reboot] 1.01 second
[21:51:05.849][DJIFirmwareUpgrader ] Wait [ version] 0.13 second
[21:51:06.098][DJIFirmwareUpgrader ] Wait [ version] 0.38 second
[21:51:06.349][DJIFirmwareUpgrader ] Wait [ version] 0.63 second
[21:51:06.598][DJIFirmwareUpgrader ] Wait [ version] 0.88 second
[21:51:06.849][DJIFirmwareUpgrader ] Wait [ version] 1.13 second
[21:51:07.099][DJIFirmwareUpgrader ] Wait [ version] 1.38 second
[21:51:07.348][DJIFirmwareUpgrader ] Wait [ version] 1.63 second
[21:51:07.599][DJIFirmwareUpgrader ] Wait [ version] 1.88 second
[21:51:07.848][DJIFirmwareUpgrader ] Wait [ version] 2.13 second
[21:51:08.098][DJIFirmwareUpgrader ] Wait [ version] 2.38 second
[21:51:08.348][DJIFirmwareUpgrader ] Wait [ version] 2.63 second
[21:51:08.598][DJIFirmwareUpgrader ] Wait [ version] 2.88 second
[21:51:08.853][DJIFirmwareUpgrader ] Wait [ version] 3.13 second
[21:51:09.099][DJIFirmwareUpgrader ] Wait [ version] 3.38 second
[21:51:09.349][DJIFirmwareUpgrader ] Wait [ version] 3.63 second
[21:51:09.598][DJIFirmwareUpgrader ] Wait [ version] 3.88 second
[21:51:09.848][DJIFirmwareUpgrader ] Wait [ version] 4.13 second
[21:51:10.098][DJIFirmwareUpgrader ] Wait [ version] 4.38 second
[21:51:10.349][DJIFirmwareUpgrader ] Wait [ version] 4.63 second
[21:51:10.598][DJIFirmwareUpgrader ] Wait [ version] 4.88 second
[21:51:10.732][DJIFirmUpgrader1 ] Success upgrade to: 00.01.09.68(App)
[21:51:10.732][DJIFirmwareUpgrader ] Wait [ version] 5.01 second
[21:51:10.732][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[21:51:10.733][DJIFirmUpgrader1 ] device type: 6, device index: 1, data size: 14376
[21:51:10.733][DJIFirmUpgrader1 ] ======================= Time : 301.08 second
[21:51:10.738][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.00 second
[21:51:10.849][DJIFirmwareUpgrader ] Wait [ query_status] 0.11 second
[21:51:11.099][DJIFirmwareUpgrader ] Wait [ query_status] 0.36 second
[21:51:11.348][DJIFirmwareUpgrader ] Wait [ query_status] 0.61 second
[21:51:11.598][DJIFirmwareUpgrader ] Wait [ query_status] 0.86 second
[21:51:11.848][DJIFirmwareUpgrader ] Wait [ query_status] 1.11 second
[21:51:12.099][DJIFirmwareUpgrader ] Wait [ query_status] 1.36 second
[21:51:12.348][DJIFirmwareUpgrader ] Wait [ query_status] 1.61 second
[21:51:12.599][DJIFirmwareUpgrader ] Wait [ query_status] 1.86 second
[21:51:12.848][DJIFirmwareUpgrader ] Wait [ query_status] 2.11 second
[21:51:13.099][DJIFirmwareUpgrader ] Wait [ query_status] 2.36 second
[21:51:13.348][DJIFirmwareUpgrader ] Wait [ query_status] 2.61 second
[21:51:13.599][DJIFirmwareUpgrader ] Wait [ query_status] 2.86 second
[21:51:13.848][DJIFirmwareUpgrader ] Wait [ query_status] 3.11 second
[21:51:14.098][DJIFirmwareUpgrader ] Wait [ query_status] 3.36 second
[21:51:14.255][DJIFirmwareUpgrader ] Wait [ query_status] 3.52 second
[21:51:14.349][DJIFirmwareUpgrader ] Wait [ prepare] 0.09 second
[21:51:14.598][DJIFirmwareUpgrader ] Wait [ prepare] 0.34 second
[21:51:14.848][DJIFirmwareUpgrader ] Wait [ prepare] 0.59 second
[21:51:15.099][DJIFirmwareUpgrader ] Wait [ prepare] 0.84 second
[21:51:15.220][DJIFirmwareUpgrader ] Wait [ prepare] 0.96 second
[21:51:17.003][DJIFirmUpgrader1 ] re-data transmission 18
[21:51:18.988][DJIFirmUpgrader1 ] re-data transmission 51
[21:51:19.079][DJIFirmwareUpgrader ] Wait [ verify] 0.01 second
[21:51:19.085][DJIFirmwareUpgrader ] Wait [ reboot] 0.01 second
[21:51:19.099][DJIFirmwareUpgrader ] Wait [ version] 0.01 second
[21:51:19.349][DJIFirmwareUpgrader ] Wait [ version] 0.26 second
[21:51:19.598][DJIFirmwareUpgrader ] Wait [ version] 0.51 second
[21:51:19.849][DJIFirmwareUpgrader ] Wait [ version] 0.76 second
[21:51:20.099][DJIFirmwareUpgrader ] Wait [ version] 1.01 second
[21:51:20.348][DJIFirmwareUpgrader ] Wait [ version] 1.26 second
[21:51:20.598][DJIFirmwareUpgrader ] Wait [ version] 1.51 second
[21:51:20.849][DJIFirmwareUpgrader ] Wait [ version] 1.76 second
[21:51:21.099][DJIFirmwareUpgrader ] Wait [ version] 2.01 second
[21:51:21.348][DJIFirmwareUpgrader ] Wait [ version] 2.26 second
[21:51:21.598][DJIFirmwareUpgrader ] Wait [ version] 2.51 second
[21:51:21.849][DJIFirmwareUpgrader ] Wait [ version] 2.76 second
[21:51:22.098][DJIFirmwareUpgrader ] Wait [ version] 3.01 second
[21:51:22.349][DJIFirmwareUpgrader ] Wait [ version] 3.26 second
[21:51:22.599][DJIFirmwareUpgrader ] Wait [ version] 3.51 second
[21:51:22.848][DJIFirmwareUpgrader ] Wait [ version] 3.76 second
[21:51:23.098][DJIFirmwareUpgrader ] Wait [ version] 4.01 second
[21:51:23.349][DJIFirmwareUpgrader ] Wait [ version] 4.26 second
[21:51:23.599][DJIFirmwareUpgrader ] Wait [ version] 4.51 second
[21:51:23.848][DJIFirmwareUpgrader ] Wait [ version] 4.76 second
[21:51:24.089][DJIFirmUpgrader1 ] Success upgrade to: 01.02.00.06(App)
[21:51:24.089][DJIFirmwareUpgrader ] Wait [ version] 5.00 second
[21:51:24.089][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[21:51:24.089][DJIFirmUpgrader1 ] device Wifi(1) is not connected!
[21:51:24.089][DJIFirmUpgrader1 ] ======================= Time : 13.36 second
[21:58:43.820][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 2% 47.51 kB/s
[21:58:44.029][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 9% 131.04 kB/s
[21:58:44.141][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 12% 161.81 kB/s
[21:58:44.366][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 18% 195.14 kB/s
[21:58:44.605][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 24% 216.71 kB/s
[21:58:44.880][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 30% 228.03 kB/s
[21:58:45.112][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 34% 225.53 kB/s
[21:58:45.397][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 38% 225.41 kB/s
[21:58:45.673][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 42% 219.98 kB/s
[21:58:46.012][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 51% 238.07 kB/s
[21:58:46.221][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 54% 233.65 kB/s
[21:58:46.459][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 57% 230.30 kB/s
[21:58:46.575][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 61% 236.35 kB/s
[21:58:46.724][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 62% 231.11 kB/s
[21:58:46.886][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 65% 233.87 kB/s
[21:58:46.994][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 69% 239.71 kB/s
[21:58:47.128][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 73% 243.55 kB/s
[21:58:47.233][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 76% 248.92 kB/s
[21:58:47.517][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 81% 247.42 kB/s
[21:58:47.641][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 84% 251.20 kB/s
[21:58:47.774][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 88% 254.29 kB/s
[21:58:47.880][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 90% 255.34 kB/s
[21:58:47.986][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 94% 259.59 kB/s
[21:58:48.107][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 96% 259.70 kB/s
[21:58:48.225][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 97% 256.87 kB/s
[21:58:48.318][DJIWebFileGetter ] Downloading [HG700_FW_V01.07.00.60.bin] 100% 258.00 kB/s
[21:58:48.319][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:58:48.323][DJIFirmServiceAgent1] Center_board, 0 Size: 77484 Hash: 6d3f8db23ec0235cde99734da205751a ENC: 0
[21:58:48.323][DJIFirmServiceAgent1] Gimbal, 1 Size: 188416 Hash: c676db0962c2f4b2dc97891fc8c09038 ENC: 0
[21:58:48.323][DJIFirmServiceAgent1] Gimbal, 0 Size: 380376 Hash: 35a67e74bb28cf0f4b011579cd969a50 ENC: 0
[21:58:48.323][DJIFirmServiceAgent1] Gimbal, 0 Size: 29196 Hash: a857e3fc7790d187885d285276337f3e ENC: 0
[21:58:48.323][DJIFirmServiceAgent1] Wifi, 0 Size: 126976 Hash: 68142a33c148e5101d85b446911d34d2 ENC: 0
[21:58:48.324][DJIFirmServiceAgent1] Remote_radio, 0 Size: 14376 Hash: 987838099390509d7e7f26d6b973940c ENC: 0
[21:58:48.324][DJIFirmServiceAgent1] Center_board, 0 Size: 320300 Hash: 5c9453879e7f35101ac7c8fd80b58d4c ENC: 0
[21:58:48.324][DJIFirmServiceAgent1] Last, 0 Size: 34460 Hash: f3c255b470e5eaede90a429ad725863e ENC: 0
[21:58:48.324][DJIFirmServiceAgent1] Battery, 0 Size: 90032 Hash: fe70fbd08adf6127225029566bec5457 ENC: 0
[21:58:48.326][DJIFirmUpgrader1 ] Skip file:Gimbal(0) 1 , version is same!
[21:58:48.329][DJIFirmUpgrader1 ] Skip file:Gimbal(1) 0 , version is same!
[21:58:48.329][DJIFirmUpgrader1 ] Skip file:Gimbal(2) 0 , version is same!
[21:58:48.329][DJIFirmUpgrader1 ] Skip file:Gimbal(3) 0 , version is same!
[21:58:48.329][DJIFirmUpgrader1 ] Skip file:Wifi(1) 0 , device is not connected!
[21:58:48.330][DJIFirmUpgrader1 ] Skip file:Center_board(6) 0 , device is not connected!
[21:58:48.330][DJIFirmUpgrader1 ] Skip fileast(5) 0 , device is not connected!
[21:58:48.330][DJIFirmUpgrader1 ] Skip file:Last(6) 0 , device is not connected!
[21:58:48.330][DJIFirmUpgrader1 ] Skip file:Last(7) 0 , device is not connected!
[21:58:48.330][DJIFirmUpgrader1 ] Skip file:Battery(0) 0 , version is same!
[21:58:48.331][DJIFirmUpgrader1 ] Total [3] file need to upgrade:
[21:58:48.331][DJIFirmUpgrader1 ] Center_board(7) Size:77484 FirmType:App
[21:58:48.331][DJIFirmUpgrader1 ] Gimbal(0) Size:380376 FirmType:App
[21:58:48.331][DJIFirmUpgrader1 ] Remote_radio(1) Size:14376 FirmType:App
[21:58:48.331][DJIFirmUpgrader1 ] End file list!
[21:58:48.331][DJIFirmUpgrader1 ] device type: 5, device index: 7, data size: 77484
[21:58:48.349][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.02 second
[21:58:48.354][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.02 second
[21:58:48.599][DJIFirmwareUpgrader ] Wait [ query_status] 0.24 second
[21:58:48.872][DJIIdentifierMgr ] Device Remove COM3
[21:58:48.872][DJISerialIo ] Free COM3 success!
[21:58:48.872][DJICmdIo ] DJICmdIo closed.
[21:58:48.872][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:58:48.872][DJIFirmwareUpgrader ] Wait [ query_status] 0.52 second
[21:58:49.098][DJIFirmwareUpgrader ] Wait [ query_status] 0.74 second
[21:58:49.349][DJIFirmwareUpgrader ] Wait [ query_status] 0.99 second
[21:58:49.599][DJIFirmwareUpgrader ] Wait [ query_status] 1.24 second
[21:58:49.849][DJIFirmwareUpgrader ] Wait [ query_status] 1.49 second
[21:58:50.131][DJIIdentifierMgr ] Device Arrive COM3
[21:58:50.131][DJICmdIo ] open COM3
[21:58:50.332][DJISerialIo ] Open COM3 success!
[21:58:50.332][DJIIdentifierMgr ] open device succeed
[21:58:50.332][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:58:50.332][gen_idf_COM3 ] Release DJIIdentifier.
[21:58:50.333][DJIFirmwareUpgrader ] Wait [ query_status] 1.98 second
[21:58:50.378][DJIFirmwareUpgrader ] Wait [ query_status] 2.02 second
[21:58:50.378][gen_idf_COM3 ] Center_board(7) quick resume in upgrading mode!!!
[21:58:50.378][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.40 ], Ldr
[21:58:50.378][DJIDeviceMgr ] device upgrading resume in loader! COM3
[21:58:50.378][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:58:50.600][DJIFirmwareUpgrader ] Wait [ query_status] 2.24 second
[21:58:50.849][DJIFirmwareUpgrader ] Wait [ query_status] 2.49 second
[21:58:50.989][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:58:51.099][DJIFirmwareUpgrader ] Wait [ query_status] 2.74 second
[21:58:51.348][DJIFirmwareUpgrader ] Wait [ query_status] 2.99 second
[21:58:51.598][DJIFirmwareUpgrader ] Wait [ query_status] 3.24 second
[21:58:51.849][DJIFirmwareUpgrader ] Wait [ query_status] 3.49 second
[21:58:51.880][DJIFirmwareUpgrader ] Wait [ query_status] 3.53 second
[21:58:52.099][DJIFirmwareUpgrader ] Wait [ prepare] 0.22 second
[21:58:52.349][DJIFirmwareUpgrader ] Wait [ prepare] 0.47 second
[21:58:52.598][DJIFirmwareUpgrader ] Wait [ prepare] 0.72 second
[21:58:52.848][DJIFirmwareUpgrader ] Wait [ prepare] 0.97 second
[21:58:53.098][DJIFirmwareUpgrader ] Wait [ prepare] 1.22 second
[21:58:53.348][DJIFirmwareUpgrader ] Wait [ prepare] 1.47 second
[21:58:53.599][DJIFirmwareUpgrader ] Wait [ prepare] 1.72 second
[21:58:53.848][DJIFirmwareUpgrader ] Wait [ prepare] 1.97 second
[21:58:54.098][DJIFirmwareUpgrader ] Wait [ prepare] 2.22 second
[21:58:54.251][DJIFirmwareUpgrader ] Wait [ prepare] 2.37 second
[21:58:57.934][DJIFirmwareUpgrader ] Wait [ verify] 0.04 second
[21:58:57.940][DJIFirmwareUpgrader ] Wait [ reboot] 0.01 second
[21:58:58.098][DJIFirmwareUpgrader ] Wait [ version] 0.16 second
[21:58:58.211][DJIIdentifierMgr ] Device Remove COM3
[21:58:58.211][DJISerialIo ] Free COM3 success!
[21:58:58.211][DJICmdIo ] DJICmdIo closed.
[21:58:58.211][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[21:58:58.349][DJIFirmwareUpgrader ] Wait [ version] 0.41 second
[21:58:58.598][DJIFirmwareUpgrader ] Wait [ version] 0.66 second
[21:58:58.849][DJIFirmwareUpgrader ] Wait [ version] 0.91 second
[21:58:59.099][DJIFirmwareUpgrader ] Wait [ version] 1.16 second
[21:58:59.348][DJIFirmwareUpgrader ] Wait [ version] 1.41 second
[21:58:59.599][DJIFirmwareUpgrader ] Wait [ version] 1.66 second
[21:58:59.848][DJIFirmwareUpgrader ] Wait [ version] 1.91 second
[21:59:00.099][DJIFirmwareUpgrader ] Wait [ version] 2.16 second
[21:59:00.349][DJIFirmwareUpgrader ] Wait [ version] 2.41 second
[21:59:00.598][DJIFirmwareUpgrader ] Wait [ version] 2.66 second
[21:59:00.850][DJIFirmwareUpgrader ] Wait [ version] 2.91 second
[21:59:01.099][DJIFirmwareUpgrader ] Wait [ version] 3.16 second
[21:59:01.349][DJIFirmwareUpgrader ] Wait [ version] 3.41 second
[21:59:01.600][DJIFirmwareUpgrader ] Wait [ version] 3.66 second
[21:59:01.655][DJIIdentifierMgr ] Device Arrive COM3
[21:59:01.655][DJICmdIo ] open COM3
[21:59:01.857][DJISerialIo ] Open COM3 success!
[21:59:01.857][DJIIdentifierMgr ] open device succeed
[21:59:01.857][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[21:59:01.857][gen_idf_COM3 ] Release DJIIdentifier.
[21:59:01.857][DJIFirmwareUpgrader ] Wait [ version] 3.92 second
[21:59:01.924][gen_idf_COM3 ] GetModuleActivateStatus1 Error! ErrorId : 2
[21:59:01.935][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.40 ], App
[21:59:01.936][DJIDeviceMgr ] device service ready! COM3
[21:59:01.936][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[21:59:02.098][DJIFirmwareUpgrader ] Wait [ version] 4.16 second
[21:59:02.117][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[21:59:02.348][DJIFirmwareUpgrader ] Wait [ version] 4.41 second
[21:59:02.599][DJIFirmwareUpgrader ] Wait [ version] 4.66 second
[21:59:02.848][DJIFirmwareUpgrader ] Wait [ version] 4.91 second
[21:59:02.932][DJIFirmUpgrader1 ] Success upgrade to: 01.00.06.40(App)
[21:59:02.932][DJIFirmwareUpgrader ] Wait [ version] 4.99 second
[21:59:02.932][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[21:59:02.932][DJIFirmUpgrader1 ] device type: 4, device index: 0, data size: 380376
[21:59:02.932][DJIFirmUpgrader1 ] ======================= Time : 14.60 second
[21:59:03.009][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.08 second
[21:59:03.098][DJIFirmwareUpgrader ] Wait [ query_status] 0.09 second
[21:59:03.349][DJIFirmwareUpgrader ] Wait [ query_status] 0.34 second
[21:59:03.598][DJIFirmwareUpgrader ] Wait [ query_status] 0.59 second
[21:59:03.849][DJIFirmwareUpgrader ] Wait [ query_status] 0.84 second
[21:59:04.099][DJIFirmwareUpgrader ] Wait [ query_status] 1.09 second
[21:59:04.348][DJIFirmwareUpgrader ] Wait [ query_status] 1.34 second
[21:59:04.598][DJIFirmwareUpgrader ] Wait [ query_status] 1.59 second
[21:59:04.850][DJIFirmwareUpgrader ] Wait [ query_status] 1.84 second
[21:59:05.099][DJIFirmwareUpgrader ] Wait [ query_status] 2.09 second
[21:59:05.348][DJIFirmwareUpgrader ] Wait [ query_status] 2.34 second
[21:59:05.599][DJIFirmwareUpgrader ] Wait [ query_status] 2.59 second
[21:59:05.848][DJIFirmwareUpgrader ] Wait [ query_status] 2.84 second
[21:59:06.099][DJIFirmwareUpgrader ] Wait [ query_status] 3.09 second
[21:59:06.348][DJIFirmwareUpgrader ] Wait [ query_status] 3.34 second
[21:59:06.526][DJIFirmwareUpgrader ] Wait [ query_status] 3.52 second
[21:59:06.598][DJIFirmwareUpgrader ] Wait [ prepare] 0.07 second
[21:59:06.849][DJIFirmwareUpgrader ] Wait [ prepare] 0.32 second
[21:59:07.098][DJIFirmwareUpgrader ] Wait [ prepare] 0.57 second
[21:59:07.348][DJIFirmwareUpgrader ] Wait [ prepare] 0.82 second
[21:59:07.599][DJIFirmwareUpgrader ] Wait [ prepare] 1.07 second
[21:59:07.849][DJIFirmwareUpgrader ] Wait [ prepare] 1.32 second
[21:59:08.099][DJIFirmwareUpgrader ] Wait [ prepare] 1.57 second
[21:59:08.348][DJIFirmwareUpgrader ] Wait [ prepare] 1.82 second
[21:59:08.590][DJIFirmwareUpgrader ] Wait [ prepare] 2.06 second
[22:01:49.599][DJIFirmwareUpgrader ] Wait [ verify] 0.03 second
[22:01:49.629][DJIFirmwareUpgrader ] Wait [ verify] 0.06 second
[22:01:49.849][DJIFirmwareUpgrader ] Wait [ reboot] 0.22 second
[22:01:50.098][DJIFirmwareUpgrader ] Wait [ reboot] 0.47 second
[22:01:50.348][DJIFirmwareUpgrader ] Wait [ reboot] 0.72 second
[22:01:50.598][DJIFirmwareUpgrader ] Wait [ reboot] 0.97 second
[22:01:50.638][DJIFirmwareUpgrader ] Wait [ reboot] 1.01 second
[22:01:50.848][DJIFirmwareUpgrader ] Wait [ version] 0.21 second
[22:01:51.098][DJIFirmwareUpgrader ] Wait [ version] 0.46 second
[22:01:51.349][DJIFirmwareUpgrader ] Wait [ version] 0.71 second
[22:01:51.599][DJIFirmwareUpgrader ] Wait [ version] 0.96 second
[22:01:51.849][DJIFirmwareUpgrader ] Wait [ version] 1.21 second
[22:01:52.099][DJIFirmwareUpgrader ] Wait [ version] 1.46 second
[22:01:52.349][DJIFirmwareUpgrader ] Wait [ version] 1.71 second
[22:01:52.599][DJIFirmwareUpgrader ] Wait [ version] 1.96 second
[22:01:52.849][DJIFirmwareUpgrader ] Wait [ version] 2.21 second
[22:01:53.098][DJIFirmwareUpgrader ] Wait [ version] 2.46 second
[22:01:53.349][DJIFirmwareUpgrader ] Wait [ version] 2.71 second
[22:01:53.598][DJIFirmwareUpgrader ] Wait [ version] 2.96 second
[22:01:53.848][DJIFirmwareUpgrader ] Wait [ version] 3.21 second
[22:01:54.098][DJIFirmwareUpgrader ] Wait [ version] 3.46 second
[22:01:54.349][DJIFirmwareUpgrader ] Wait [ version] 3.71 second
[22:01:54.599][DJIFirmwareUpgrader ] Wait [ version] 3.96 second
[22:01:54.849][DJIFirmwareUpgrader ] Wait [ version] 4.21 second
[22:01:55.098][DJIFirmwareUpgrader ] Wait [ version] 4.46 second
[22:01:55.348][DJIFirmwareUpgrader ] Wait [ version] 4.71 second
[22:01:55.598][DJIFirmwareUpgrader ] Wait [ version] 4.96 second
[22:01:55.641][DJIFirmUpgrader1 ] Success upgrade to: 00.01.09.68(App)
[22:01:55.641][DJIFirmwareUpgrader ] Wait [ version] 5.00 second
[22:01:55.641][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[22:01:55.641][DJIFirmUpgrader1 ] device type: 6, device index: 1, data size: 14376
[22:01:55.642][DJIFirmUpgrader1 ] ======================= Time : 172.71 second
[22:01:55.647][DJIFirmwareUpgrader ] Wait [ enter_upgrade] 0.00 second
[22:01:55.849][DJIFirmwareUpgrader ] Wait [ query_status] 0.20 second
[22:01:56.099][DJIFirmwareUpgrader ] Wait [ query_status] 0.45 second
[22:01:56.348][DJIFirmwareUpgrader ] Wait [ query_status] 0.70 second
[22:01:56.599][DJIFirmwareUpgrader ] Wait [ query_status] 0.95 second
[22:01:56.848][DJIFirmwareUpgrader ] Wait [ query_status] 1.20 second
[22:01:57.099][DJIFirmwareUpgrader ] Wait [ query_status] 1.45 second
[22:01:57.349][DJIFirmwareUpgrader ] Wait [ query_status] 1.70 second
[22:01:57.599][DJIFirmwareUpgrader ] Wait [ query_status] 1.95 second
[22:01:57.849][DJIFirmwareUpgrader ] Wait [ query_status] 2.20 second
[22:01:58.099][DJIFirmwareUpgrader ] Wait [ query_status] 2.45 second
[22:01:58.349][DJIFirmwareUpgrader ] Wait [ query_status] 2.70 second
[22:01:58.599][DJIFirmwareUpgrader ] Wait [ query_status] 2.95 second
[22:01:58.849][DJIFirmwareUpgrader ] Wait [ query_status] 3.20 second
[22:01:59.098][DJIFirmwareUpgrader ] Wait [ query_status] 3.45 second
[22:01:59.158][DJIFirmwareUpgrader ] Wait [ query_status] 3.51 second
[22:01:59.349][DJIFirmwareUpgrader ] Wait [ prepare] 0.19 second
[22:01:59.600][DJIFirmwareUpgrader ] Wait [ prepare] 0.44 second
[22:01:59.849][DJIFirmwareUpgrader ] Wait [ prepare] 0.69 second
[22:02:00.099][DJIFirmwareUpgrader ] Wait [ prepare] 0.94 second
[22:02:00.117][DJIFirmwareUpgrader ] Wait [ prepare] 0.96 second
[22:02:00.982][DJIFirmwareUpgrader ] Wait [ verify] 0.01 second
[22:02:00.993][DJIFirmwareUpgrader ] Wait [ reboot] 0.01 second
[22:02:01.099][DJIFirmwareUpgrader ] Wait [ version] 0.10 second
[22:02:01.348][DJIFirmwareUpgrader ] Wait [ version] 0.35 second
[22:02:01.599][DJIFirmwareUpgrader ] Wait [ version] 0.61 second
[22:02:01.850][DJIFirmwareUpgrader ] Wait [ version] 0.86 second
[22:02:02.099][DJIFirmwareUpgrader ] Wait [ version] 1.11 second
[22:02:02.348][DJIFirmwareUpgrader ] Wait [ version] 1.35 second
[22:02:02.599][DJIFirmwareUpgrader ] Wait [ version] 1.61 second
[22:02:02.848][DJIFirmwareUpgrader ] Wait [ version] 1.85 second
[22:02:03.098][DJIFirmwareUpgrader ] Wait [ version] 2.10 second
[22:02:03.349][DJIFirmwareUpgrader ] Wait [ version] 2.36 second
[22:02:03.598][DJIFirmwareUpgrader ] Wait [ version] 2.60 second
[22:02:03.848][DJIFirmwareUpgrader ] Wait [ version] 2.85 second
[22:02:04.100][DJIFirmwareUpgrader ] Wait [ version] 3.11 second
[22:02:04.348][DJIFirmwareUpgrader ] Wait [ version] 3.35 second
[22:02:04.599][DJIFirmwareUpgrader ] Wait [ version] 3.61 second
[22:02:04.850][DJIFirmwareUpgrader ] Wait [ version] 3.86 second
[22:02:05.099][DJIFirmwareUpgrader ] Wait [ version] 4.11 second
[22:02:05.348][DJIFirmwareUpgrader ] Wait [ version] 4.35 second
[22:02:05.599][DJIFirmwareUpgrader ] Wait [ version] 4.61 second
[22:02:05.849][DJIFirmwareUpgrader ] Wait [ version] 4.86 second
[22:02:05.997][DJIFirmUpgrader1 ] Success upgrade to: 01.02.00.06(App)
[22:02:05.997][DJIFirmwareUpgrader ] Wait [ version] 5.00 second
[22:02:05.997][DJIFirmUpgrader1 ] ======================= UPGRADE SUCCESS! success get version after boot
[22:02:05.997][DJIFirmUpgrader1 ] device Wifi(1) is not connected!
[22:02:05.997][DJIFirmUpgrader1 ] ======================= Time : 10.36 second
[22:11:21.340][DJIIdentifierMgr ] Device Remove COM3
[22:11:21.340][DJISerialIo ] Free COM3 success!
[22:11:21.340][DJICmdIo ] DJICmdIo closed.
[22:11:21.340][DJIDeviceMgr ] DevRemoved, Center_board, hg700, 01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b
[22:43:59.056][DJIIdentifierMgr ] Device Arrive COM3
[22:43:59.056][DJICmdIo ] open COM3
[22:43:59.258][DJISerialIo ] Open COM3 success!
[22:43:59.258][DJIIdentifierMgr ] open device succeed
[22:43:59.258][gen_idf_COM3 ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[22:43:59.258][gen_idf_COM3 ] Release DJIIdentifier.
[22:43:59.340][gen_idf_COM3 ] GetModuleActivateStatus1 Error! ErrorId : 2
[22:43:59.352][DJIIdentifierMgr ] [Center_board , hg700 , 01.00.06.40 ], App
[22:43:59.352][DJIDeviceMgr ] device service ready! COM3
[22:43:59.353][DJIDeviceMgr ] DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[22:44:00.088][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:11.114][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[22:44:11.231][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:11.384][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:11.638][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[22:44:11.777][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:13.158][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[22:44:13.188][DJIDeviceMgr ] Refresh DevArrival, Center_board, hg700, ,01.00.06.40, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[22:44:13.225][DJIUpgradeMgr ] ServiceUrl : https://mydjiflight.dji.com/links/links/hg700
[22:44:13.225][DJIUpgradeView ] userType :
[22:44:13.230][DJIDeviceInfoEnumera] 5% 1/17 GCU(7)
[22:44:13.230][DJIDeviceInfoEnumera] 11% 2/17 IMU(0)
[22:44:13.231][DJIDeviceInfoEnumera] 17% 3/17 Pitch(1)
[22:44:13.238][DJIDeviceInfoEnumera] 23% 4/17 Roll(2)
[22:44:13.238][DJIDeviceInfoEnumera] 29% 5/17 Battery(0)
[22:44:13.393][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:13.394][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:13.613][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:13.614][DJIWebFileGetter ] [OnFinish]reply statusCode=200
[22:44:13.736][DJIDeviceInfoEnumera] 35% 6/17 Focus_Wheel(1)
[22:44:14.037][DJIDeviceInfoEnumera] 41% 7/17 Yaw(3)
[22:44:15.249][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Bluetooth(7:1)
[22:44:15.249][DJIDeviceInfoEnumera] 47% 8/17 Bluetooth(1)
[22:44:15.249][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD(5:6)
[22:44:15.249][DJIDeviceInfoEnumera] 52% 9/17 LCD(6)
[22:44:15.249][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD_flash(5:3)
[22:44:15.249][DJIDeviceInfoEnumera] 58% 10/17 LCD_flash(3)
[22:44:15.259][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: On-board Mount(5:0)
[22:44:15.259][DJIDeviceInfoEnumera] 64% 11/17 On-board Mount(0)
[22:44:15.259][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Handler(5:4)
[22:44:15.259][DJIDeviceInfoEnumera] 70% 12/17 Focus Handler(4)
[22:44:15.259][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: RC Handler(5:5)
[22:44:15.259][DJIDeviceInfoEnumera] 76% 13/17 RC Handler(5)
[22:44:15.259][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: EXT_GPS(5:1)
[22:44:15.259][DJIDeviceInfoEnumera] 82% 14/17 EXT_GPS(1)
[22:44:15.260][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Motor(31:5)
[22:44:15.260][DJIDeviceInfoEnumera] 88% 15/17 Focus Motor(5)
[22:44:15.269][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Iris Motor (31:6)
[22:44:15.269][DJIDeviceInfoEnumera] 94% 16/17 Iris Motor (6)
[22:44:15.269][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Zoom Motor(31:7)
[22:44:15.269][DJIDeviceInfoEnumera] 100% 17/17 Zoom Motor(7)
[22:44:15.269][DJIDeviceInfoEnumera] GCU (5 :7) Ldr : 01.00.03.00 App : 01.00.06.40
[22:44:15.269][DJIDeviceInfoEnumera] IMU (4 :0) Ldr : 09.01.00.17 App : 00.01.10.15 GB09
[22:44:15.269][DJIDeviceInfoEnumera] Pitch (4 :1) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[22:44:15.269][DJIDeviceInfoEnumera] Roll (4 :2) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[22:44:15.269][DJIDeviceInfoEnumera] Yaw (4 :3) Ldr : 01.00.00.03 App : 01.00.00.10 GB09
[22:44:15.269][DJIDeviceInfoEnumera] Bluetooth (7 :1) device no reply, request timeout!
[22:44:15.269][DJIDeviceInfoEnumera] Focus_Wheel (6 :1) Ldr : 01.00.00.00 App : 02.02.00.07
[22:44:15.269][DJIDeviceInfoEnumera] LCD (5 :6) device no reply, request timeout!
[22:44:15.269][DJIDeviceInfoEnumera] LCD_flash (5 :3) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] Focus Handler (5 :4) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] RC Handler (5 :5) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] Battery (11:0) Ldr : 00.00.00.01 App : 04.73.05.07 HG700BATTERY
[22:44:15.270][DJIDeviceInfoEnumera] EXT_GPS (5 :1) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] Focus Motor (31:5) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] Iris Motor (31:6) device no reply, request timeout!
[22:44:15.270][DJIDeviceInfoEnumera] Zoom Motor (31:7) device no reply, request timeout!
[22:44:15.270][DJIServerApi ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700 |
