djiuser_Tuuz94kwu5xM
Flight distance : 1643907 ft
So I have the BT-30E (BT-300 headset paired with the BT-35E Interface unit) and Im having an issue with mild blurriness, approx 50-60% of the image, from center outward. Its not unusably blurry but enough to have trouble reading numbers & words. The edges are completely clear/crisp.
I havent had my eyes checked in sometime but Ive never had any issues with my sight. I also have the DJI Goggles RE and those are perfectly clear (w/ the IPD adj set in the middle of its range).
Really, I dont believe its an issue w/ my IPD?
My IPD measures at 2.5-2.6 inches, which as I read it, is right in the middle of the range Epson states.
I have searched these forums for anything similiar to my issue but all Ive found were issues relating to peoples IPD, which as I understand it, affects the edges of the image, right?
Ive read about the SmartGold inserts but those seem to be meant fir the IPD issue as well.
In a desparate attempt to get clarity, I tried testing some reading glasses, but the lowest, 1.25, were WAY too blurry everywhere.
Ive tried the adjustments of moving the glasses in/out, side to side, etc but I only see slight changes to the blurriness and the affected srea seems to move with the glasses, so Im wondering if its my vision at all?
Im just hoping to learn if this is an issue that others are seeing with the BT-300 series glasses or if my eyes are most likely the problem, and if thsts the case, what can I even do about it?
Thx for any help! |
